Post by Tommy on Sept 4, 2018 10:30:07 GMT -5
zarguy
Member since December 2005
Post by zarguy on Sept 4, 2018 10:49:25 GMT -5
Tommy - I wonder if the first one is a variation or Rhodonite. Lynn
Post by Deleted on Sept 4, 2018 11:44:25 GMT -5
Maybe something metamorphic, such as a mylonite (with feldspar clasts) for the first.
I agree that the second looks like cinnabar. If the white is opal, then perhaps myrickite (still, with a lot of cinnabar).
Post by fernwood on Sept 4, 2018 13:10:21 GMT -5
First one also looks like it contains feldspar. Yes, second one has some cinnabar in it.
Post by Tommy on Sept 4, 2018 14:29:08 GMT -5
Tommy - I wonder if the first one is a variation or Rhodonite. Thanks Lynn, it's definitely possible although I see a lot of Rhodonite around here and I've never seen this type of pattern. The color is much more salmon than pink too.
Post by Tommy on Sept 4, 2018 14:33:38 GMT -5
Post by Deleted on Sept 4, 2018 14:44:44 GMT -5
Very pretty, but better for the specimen shelf than jewelry.
Post by rockjunquie on Sept 4, 2018 15:13:39 GMT -5
Damn- too bad you can't cab it. It's gorgeous.... but can you seal it and cab it?
Post by Tommy on Sept 4, 2018 15:25:42 GMT -5
Damn- too bad you can't cab it. It's gorgeous.... but can you seal it and cab it? It's possible. I have one decent size slab that didn't fall apart and I do plan on putting it aside until I get some Opticon - or the stuff zarguy uses. Might take me a while to get around to it though.
Post by rockjunquie on Sept 4, 2018 15:30:15 GMT -5
Damn- too bad you can't cab it. It's gorgeous.... but can you seal it and cab it? It's possible. I have one decent size slab that didn't fall apart and I do plan on putting it aside until I get some Opticon - or the stuff zarguy uses. Might take me a while to get around to it though. I can't think of many better uses for a sealer than this. Let us know if/when you do it.
Post by vegasjames on Sept 4, 2018 17:39:49 GMT -5
The first one looks like the stuff I found in Kokoweef. Some of it also contains epidote making it appear to be some form of unakite with larger crystal structure.
Post by rockjunquie on Sept 5, 2018 15:52:47 GMT -5
I was thinking unakite, too, with that salmon color, but the rest doesn't seem right.
Post by vegasjames on Sept 5, 2018 18:24:06 GMT -5
Here is a cab from the material I found in the Kokoweef area years ago: DSC_0743 by James Sloane, on Flickr
Post by vegasjames on Sept 5, 2018 18:25:30 GMT -5
I was thinking unakite, too, with that salmon color, but the rest doesn't seem right. It is missing the green epidote. But the pink does look like the orthoclase of unakite.
Post by stardiamond on Sept 7, 2018 20:18:25 GMT -5
Damn- too bad you can't cab it. It's gorgeous.... but can you seal it and cab it? I believe this is cinnabar. I cabbed it years ago. Picture was cropped from one of my riker box photos.
