Post by sophia13 on Sept 20, 2018 8:08:12 GMT -5
***Update**** found belt info and ordered off Grainger. Still need belt info for my 8" Raytech Gem Maker.
Post by woodman on Sept 20, 2018 9:09:48 GMT -5
I need belts for my Raytech ls 6 and ls10 saws. Does anyone have parts #s, tried looking in manuals but doesn't specify other than v belt. Thank you. I'm googling too If you have the old ones, take them to Ace hardware, they have a good supply of belts and is where I get mine.
Post by sophia13 on Sept 20, 2018 9:18:35 GMT -5
Found online at Grainger once got part #s, old ones gone . Still looking for Raytech 8" Gem Maker belt specs. Can't read on belt. Thank you.
agatemaggot
Member since August 2006
Post by agatemaggot on Sept 20, 2018 9:19:33 GMT -5
If you don't have an Ace in town, go to any bearing supply house with your old belts and they can fix you right up !
Post by woodman on Sept 20, 2018 9:20:34 GMT -5
Found online at Grainger once got part #s, old ones gone . Still looking for Raytech 8" Gem Maker belt specs. Can't read on belt. Thank you. If you don't have an old one, you can take a piece of rope about the size of the pulley and wrap it around and measure the length, you will get real close that way.
zarguy
Member since December 2005
Post by zarguy on Sept 20, 2018 9:46:12 GMT -5
Post by johnjsgems on Sept 20, 2018 12:31:31 GMT -5
Or auto parts. Any real hardware store will have a measurer. If the old belt is shot you can cut it and measure it laying straight. It may have stretched a little so get next standard size shorter.
Post by woodman on Sept 20, 2018 13:31:53 GMT -5
I have one of these on a bullwheel and it works great, did not want to take it apart to put a new belt on it. A friend of mine buys it in bulk and uses it on all of his saws and sanders.
NDK
Post by NDK on Sept 20, 2018 13:46:11 GMT -5
Another vote for the link belt. Agree they're expensive compared to a v belt, but they have no memory so if your machine sits for long periods of time without use like mine sometimes do there's no wobble at start up.
Post by sophia13 on Sept 20, 2018 14:43:14 GMT -5
Thanks, think I'm set. Ordered regular ones but I'm going to get one of those link belts to try
Post by Rockoonz on Sept 20, 2018 21:08:32 GMT -5
I'm going to have to go ahead and vote strongly AGAINST link belt, especially on slab saws. They have a lot less contact area against the v belt pulleys, will stretch over time and cause things to slip. On a saw with an electric feed motor, if the blade stops the feed doesn't. I saw a blade on a lortone ls12 turned into something resembling a potato chip as a result. The one I originally got for my 18" HP saw also slipped and stretched, after a few weeks I had to take a couple links out as it stretched so far I ran out of adjustment. After having it stall on a rock I got a regular belt and no problems since. The green Dayton belts designed for mower drives on yard tractors are the best IMO. Make sure it's always a fractional horsepower bely, not an automotive belt.
