Post by miket on May 17, 2019 9:54:27 GMT -5
I got this from Tela, we're thinking it's verdite. I love the green color. It was kind of funny, I'm used to grinding on agates and jaspers with my dremel and when I started on this it was like grinding plastic! I think I had the whole thing shaped in 15 minutes and now I'm trying to figure out how to polish it once I get the scratch in the bottom removed. Not sure if you can put this stuff in a rotary or not, I've never worked with anything this soft. Thanks for looking.
followthatcab
Member since May 2019
Post by followthatcab on May 17, 2019 17:23:27 GMT -5
Looking good! I've seen some of your latest projects, I think this is my favourite so far.
Post by miket on May 17, 2019 20:02:55 GMT -5
Looking good! I've seen some of your latest projects, I think this is my favourite so far. Thanks, funniest thing is that it was by far the easiest and quickest. I may have to hand polish it sometime I don't know how it would behave in a rotary. Still have two more pieces of it maybe I'll try to get more creative with them.
followthatcab
Post by followthatcab on May 18, 2019 11:05:23 GMT -5
Looks like this material is a bit more malleable with a dremel because it's soft. I'm looking forward to the next cabs!
Post by fernwood on May 18, 2019 11:28:26 GMT -5
Wondering. What if you made your own Polishing medium to use with Dremel? My latest experiment was mixing Rapid Polish and grape seed oil. Used that with felt pad on the Dremel. Worked out great.
Post by miket on May 18, 2019 12:11:37 GMT -5
Wondering. What if you made your own Polishing medium to use with Dremel? My latest experiment was mixing Rapid Polish and grape seed oil. Used that with felt pad on the Dremel. Worked out great. I might just try that, thanks!
