Post by miket on May 18, 2019 17:30:52 GMT -5
Here's what happens when a running dremel hits the floor. The only positive is that the bit was about used up. 🙄
Post by Rockindad on May 18, 2019 17:37:18 GMT -5
I thought that was for grinding around corners Al
Oops.
May 18, 2019 23:05:51 GMT -5
miket likes this
Post by MsAli on May 18, 2019 23:05:51 GMT -5
You need the flex shaft
Post by miket on May 19, 2019 4:58:41 GMT -5
I thought that was for grinding around corners Al 🤣 Good one!
Oops.
May 19, 2019 5:00:27 GMT -5
Post by miket on May 19, 2019 5:00:27 GMT -5
I really do. I need a lot of things, that's for sure on the list! Still chuckling about grinding around corners 😁
Kai
Member since December 2018
Oops.
May 19, 2019 5:17:06 GMT -5
miket likes this
Post by Kai on May 19, 2019 5:17:06 GMT -5
Ouch!
Oops.
May 19, 2019 7:58:37 GMT -5
Post by MsAli on May 19, 2019 7:58:37 GMT -5
What dremel do you have?
Oops.
May 19, 2019 10:31:02 GMT -5
Post by miket on May 19, 2019 10:31:02 GMT -5
I have a corded craftman that I need to work on, a cordless dremel that might as well go in the trash for as much good as it does, and the cheaper one speed corded dremel. I don't know the model but that's the one that I dropped.
