sheriam
Member since December 2019
Post by sheriam on Feb 19, 2020 3:52:04 GMT -5
Oh, I forgot one.
I got a bag of agates, but some of them are cracked oben, like this: Can/should these still be tumbled?
Post by rmf on Feb 19, 2020 4:10:46 GMT -5
you can pour epoxy in the cavity then dissolve it out when done that will keep the grit from stacking up inside. the cavity will fill up with grit and fine rocks and mud. It will be hard to clean.
sheriam
Post by sheriam on Feb 19, 2020 5:15:21 GMT -5
you can pour epoxy in the cavity then dissolve it out when done that will keep the grit from stacking up inside. the cavity will fill up with grit and fine rocks and mud. It will be hard to clean. Ah, thanks!
Post by knave on Feb 19, 2020 5:53:40 GMT -5
I believe silicon will work also. In my last batch I had some small glass beads with the ceramics in the vibe. A couple of pendant style rocks with holes predrilled. I was Amazed how tightly the small glass stuck in the pendant holes. No way to get it out with my fingernail. Had to poke at it from the other side with a dremel bit.
Post by joshuamcduffie on Feb 19, 2020 8:17:12 GMT -5
When I get one like that, I just pull it out. It's now a shelf specimen.
Post by Garage Rocker on Feb 19, 2020 9:13:31 GMT -5
Don't sleep on those agates with vugs or cavities. They take a little care in cleanouts, but they make for some interesting tumbles. I did not fill these with silicone, wax, glue or anything. I had to pry some ceramics out of the larger cavity, then high pressure water and an electric toothbrush.
sheriam
Post by sheriam on Feb 19, 2020 14:44:02 GMT -5
When I get one like that, I just pull it out. It's now a shelf specimen. Yeah, I'd do that, too, if I like the specimen. But there are quite a few like that, so I thought I'd try to tumble some, and keep the nicer ones
sheriam
Post by sheriam on Feb 19, 2020 14:44:23 GMT -5
Don't sleep on those agates with vugs or cavities. They take a little care in cleanouts, but they make for some interesting tumbles. I did not fill these with silicone, wax, glue or anything. I had to pry some ceramics out of the larger cavity, then high pressure water and an electric toothbrush. These look nice, thanks
Post by joshuamcduffie on Feb 19, 2020 14:49:58 GMT -5
When I get one like that, I just pull it out. It's now a shelf specimen. Yeah, I'd do that, too, if I like the specimen. But there are quite a few like that, so I thought I'd try to tumble some, and keep the nicer ones Toothbrush and a water pik then, or time between grits in a tumbler full of soapy water.
sheriam
Post by sheriam on Feb 20, 2020 1:21:07 GMT -5
Yeah, I'd do that, too, if I like the specimen. But there are quite a few like that, so I thought I'd try to tumble some, and keep the nicer ones Toothbrush and a water pik then, or time between grits in a tumbler full of soapy water. Haha, a washing cycle in the tumbler, I like that. Thx
Benathema
Member since November 2019
Post by Benathema on Feb 20, 2020 13:11:44 GMT -5
In a video of a giant super huge crazy lace a guy tumbled he protected areas with hot glue. Not sure how much of a pain it'd be to remove from a hole, but it's a thought.
