rockstock
Member since April 2019
Post by rockstock on Mar 3, 2020 17:22:19 GMT -5
Post by knave on Mar 3, 2020 17:36:56 GMT -5
Maybe itโs time to sell some of your rockstock๐
rockstock
Post by rockstock on Mar 3, 2020 18:12:26 GMT -5
Whatttt??
What would you call this if you sold it?? Ha
Post by mohs on Mar 3, 2020 18:45:26 GMT -5
unique what ever caused those dimples where was it found ?
Post by knave on Mar 3, 2020 18:46:57 GMT -5
The dimples are so evenly spaced itโs almost like itโs a track from a steel wheel
Post by Deleted on Mar 3, 2020 19:41:53 GMT -5
Reminds me of Sigillaria and Lepidodendron trunks (late Paleozoic).
pizzano
Member since February 2018
Post by pizzano on Mar 3, 2020 20:10:44 GMT -5
If you inspect the indentations closely (magnifying glass), you may find the reminiscent of teeth marks or vertical lines left from the Brachiopod or Carboniferous coral that had attached themselves to that rock during the Cambrian period....coral type animals. My son and I have found many of these in various locations around Utah, north Arizona, Calif, even in Colorado.........They uniformly clustered together, giving each other enough room to grow (expand).....once it got to crowded, they'd detach and find another location to attache themselves.........it's a good find, but rather common in the locations stated.
rockstock
Post by rockstock on Mar 3, 2020 20:37:21 GMT -5
Thank you for that info, first I've seen of it.
It was from the middle of Michigan.
Based on the ends I assume it's best as is and cutting would do no good?
Post by Deleted on Mar 4, 2020 3:32:33 GMT -5
It was from the middle of Michigan. Based on the ends I assume it's best as is and cutting would do no good? Very probably Sigillaria or Lepidodendron trunk or branch then. Both have been found along the Grand River in central Michigan. I think you could take a slice off the less attractive end and polish to display the cross-section for a specimen. You might want to go back and see if you can find any fossil cones (collectors get excited over them). Here is an article with a drawing of a cone.
rockstock
Post by rockstock on Mar 4, 2020 6:53:36 GMT -5
Very interesting, thank you.
There is no where to go back to. However frost works pushing rocks up to the surface in fields is about it and pretty random.
Post by beefjello on Mar 4, 2020 19:31:10 GMT -5
Man that's a wild one!
Post by rmf on Mar 4, 2020 22:26:13 GMT -5
rockstock That is a Stigmarian. this is a form genera of a fossil tree root. frequently found in TN, KY, WV, AL
Post by fernwood on Mar 5, 2020 6:53:58 GMT -5
rockstock That is a Stigmarian. this is a form genera of a fossil tree root. frequently found in TN, KY, WV, AL Interesting. I have a similar looking piece, found on my WI land.
Post by Fossilman on Mar 5, 2020 11:24:59 GMT -5
I would window that and run a polish on the cut piece.... Clean it up and keep it!
rockstock
Post by rockstock on Mar 5, 2020 11:41:29 GMT -5
I would window that and run a polish on the cut piece.... Clean it up and keep it! What do you mean exactly? Cut the ends smooth and polish the ends? I don't know if you'd do anything to the outside to avoid losing those details? Thanks!
pizzano
Post by pizzano on Mar 5, 2020 13:15:17 GMT -5
I would window that and run a polish on the cut piece.... Clean it up and keep it! What do you mean exactly? Cut the ends smooth and polish the ends? I don't know if you'd do anything to the outside to avoid losing those details? Thanks! Yes........that's exactly what Fossilman is suggesting.........however, it may not take to a polish easily due to it's matrix and hardness. If it's agate hard and does not crumble or waste away while sanding like some calcified, coral, sea shell, or sand stone embedded material does, it may take to a hand application semi-glossy finish........won't know until you try. As for those abundant small holes on it's surface, I'm still inclined to believe some kind of ancient life (coral, worm, ect.), attached it's self to that submerged root/trunk during some stage after the "trunk/root" life was over and started decomposing..........just a thought.
Post by rmf on Mar 5, 2020 22:46:33 GMT -5
rockstock That is a Stigmarian. this is a form genera of a fossil tree root. frequently found in TN, KY, WV, AL Interesting. I have a similar looking piece, found on my WI land. Yes but WI does not have any Pennsylvanian sediments that I am aware of so it is most likely something else or it was transported.
Post by fernwood on Mar 6, 2020 0:38:40 GMT -5
Interesting. I have a similar looking piece, found on my WI land. Yes but WI does not have any Pennsylvanian sediments that I am aware of so it is most likely something else or it was transported. Agree.
