Post by stardiamond on Mar 19, 2020 14:28:50 GMT -5
My left side wheels on my Genie have been frozen for more than a year. I even bought a pump kit to replace the belt but it requires removing the wheels to install. I had a piece of Royal Imperial that I had faced on my slab saw so I could glue it to a board. No pattern showed where I cut but as I was removing the rock I saw the pattern peeking out from uncut surface. I don't like using my slab saw to face because it wears out blades. Since I had a flat side to get a square cut. I decided to face the pattern. After completing the cut. The cut piece wedged between the blade and the deck. I immediately turned off the Genie, but before that the left side wheels unscrewed themselves. This had happened years ago when the Genie trim saw jammed. I now have access to the left side and a faced piece of rough. I had to beat on the rock to get it loose but the blade wasn't damaged.
Post by Pat on Mar 19, 2020 14:53:48 GMT -5
Beautiful piece! You were lucky, too.
