Getta Grip
Member since November 2016
Post by Getta Grip on Mar 24, 2020 10:56:02 GMT -5
Greetings Rockers!
In a couple hours I'm going to pick up a Highland Park B26 wet belt sander. It has a belt on one side and a buffing pad on the other.
This unit is missing the buffer shroud. Does anybody have one of these shrouds laying around? I think it's the same shroud used on the B series combo units.
Have any of you used a B26 sander? I'm thinking of replacing the buffer with a diamond lap.
AzRockGeek
Member since September 2016
Post by AzRockGeek on Mar 24, 2020 11:13:42 GMT -5
How funny, I just picked one up over the weekend. I got it rewired and changed the foam on the bottom wheel, need to get some belts ordered today. I am eager to hear any feedback on other people who are currently using one as well. tim
Post by mohs on Mar 24, 2020 17:39:45 GMT -5
that yard rocks
good luck with your machine belt'n cool
AzRockGeek
Post by AzRockGeek on Mar 26, 2020 9:25:19 GMT -5
Greetings Rockers! In a couple hours I'm going to pick up a Highland Park B26 wet belt sander. It has a belt on one side and a buffing pad on the other. This unit is missing the buffer shroud. Does anybody have one of these shrouds laying around? I think it's the same shroud used on the B series combo units. Have any of you used a B26 sander? I'm thinking of replacing the buffer with a diamond lap. Did you pick it up yet? If so, please share some pic's.
Getta Grip
Post by Getta Grip on Mar 29, 2020 9:35:06 GMT -5
Getta Grip
Post by Getta Grip on Mar 29, 2020 11:02:21 GMT -5
I have some slabs with bad saw marks. I would like to salvage and maybe polish them on this machine. I expect I will need a range of belt grits, starting around 100 grit and going up to ?? How fine do I need to go before moving to a polishing wheel? What range belts would you want to have, to clean up slabs and polish them? Thanks in advance for your thoughts Glen
Post by woodman on Mar 29, 2020 11:12:39 GMT -5
I have some slabs with bad saw marks. I would like to salvage and maybe polish them on this machine. I expect I will need a range of belt grits, starting around 100 grit and going up to ?? How fine do I need to go before moving to a polishing wheel? What range belts would you want to have, to clean up slabs and polish them? Thanks in advance for your thoughts Glen On my bull wheel sander, I start with 100 and then go to 400 and then to the polisher. kind of depends on the material tho. I was using 100, 220 then 400 but found i got just as good of reslts by just skipping the 220.. Good luck!
AzRockGeek
Post by AzRockGeek on Mar 29, 2020 19:51:07 GMT -5
Nice!!!! Looks in great shape other then the missing shroud for the polishing head. I have been playing with mine the last few days, I ordered belts from 100-1000, as Woodman stated, there is a close to polish after the 400. I ordered my belts from Lapidary Mart, it is the first time I ordered from them and recommend them. Good price, fast delivery and several emails on updates of shipments. 5-Stars. www.lapidarymart.com/collections/sanding-belts?custom=SandingTim
Post by knave on Mar 29, 2020 21:05:46 GMT -5
I looked all over for a “set” of belts like above, thanks for posting.
Getta Grip
Post by Getta Grip on Apr 11, 2020 8:33:17 GMT -5
Greetings Everyone, I would appreciate hearing your opinion on belts for my B26 belt sander. A good deal on diamond belts is about $140 each. I can get SIC (silicon Carbide) belts for about $15 each. I know diamond will outlast SIC, but how much? I can almost get 10 Sic belts for the price of one diamond belt. Any thoughts or opinions?
Another thought.... Does anyone know if a spent belt can be re-coated with a diamond slurry? I know this is done with wheels but I don't know if it can be done to belts. The resin would have to be pretty flexible. Again, I would very much appreciate your thoughts and comments.
Thanks Glen
