textriguy
Member since February 2020
Post by textriguy on May 25, 2020 11:15:33 GMT -5
Been seeing a lot of good things about the richardson ranch buffer. However it is just as fast as my cabking. I'm looking for something slower in that build. Our can someone tell a NOVICE how to slow it down.
Post by opalpyrexia on May 25, 2020 14:41:38 GMT -5
Are you asking about the Richardson Ranch buffer? Normally one would choose a smaller drive pulley or a larger shaft pulley, or both, but their buffer is maxed out.
You could choose to polish closer to the center of the pad. A point halfway from the outer edge of the pad is moving half the speed of the edge of the pad. So you could choose a speed by choosing what part of the pad to use. Does that help?
hummingbirdstones2
Vince A., 1958-2023
Member since August 2018
Post by hummingbirdstones2 on May 25, 2020 22:41:10 GMT -5
I'm also confused about which unit you're asking about.
We have a Richardson's buffer - a 12" diameter polishing head turned by a 12" pulley coming off a 1-1/2" pulley on a 1/4 HP motor.
They also make a high-speed sander.
Post by rmf on May 26, 2020 12:14:39 GMT -5
Are you talking about the rpm of the grinder or are you asking about how to cut soft stones slower?
textriguy
Post by textriguy on Jun 20, 2020 19:18:12 GMT -5
Sorry, yes I'm talking about how to slow the rpms down maybe by half. Several if the variscite/turquoise crabbers talk about slower rpms vs the rpms on the cabking 8 end flat lap
