billyum
Member since May 2020
Post by billyum on May 28, 2020 16:07:55 GMT -5
Hi everyone!! I am brand new to my tumbler and would like some direction on how to polish my Oregon sunstones without rounding them if that's possible. I love the rough fractal look but I want to bring out more clarity. Thank you for your time and help.
stonemon
Member since January 2017
Post by stonemon on May 28, 2020 16:26:22 GMT -5
Welcome to the forum!
Post by knave on May 28, 2020 17:44:42 GMT -5
Welcome from Wisconsin.
gatorflash1
Post by gatorflash1 on May 28, 2020 18:24:07 GMT -5
Welcome from Delaware. Tumbling with minimal rounding is best accomplished by a Vibratory tumbler.
Post by knave on May 28, 2020 18:24:40 GMT -5
Welcome from Delaware. Tumbling with minimal rounding is best accomplished by a Rotary tumbler. Did you mean, vibratory?
agatemaggot
Member since August 2006
Post by agatemaggot on May 28, 2020 18:28:39 GMT -5
Vibratory absolutely !
Post by hummingbirdstones on May 28, 2020 18:30:57 GMT -5
Welcome from Northern Arizona!
Post by RocksInNJ on May 28, 2020 19:06:13 GMT -5
Welcome from New Jersey.
Post by drocknut on May 28, 2020 19:40:46 GMT -5
Welcome to the forum from Arizona. I have tumbled Oregon Sunstones but mine came out rounded which I didn't mind.
Post by greig on May 29, 2020 16:05:23 GMT -5
You can get less rounding by either skipping stage 1 (coarse) or tumbling stage 1 & 2 for a shorter time.
dreamrocks
Member since November 2018
Post by dreamrocks on May 30, 2020 18:48:10 GMT -5
Welcome from Maine
Post by quartz on May 30, 2020 21:48:03 GMT -5
I've tumbled lots of sunstones in sand just to clean it up, it brightens up somewhat. That might give you the look you want.
gatorflash1
Post by gatorflash1 on May 31, 2020 19:15:55 GMT -5
Welcome from Delaware. Tumbling with minimal rounding is best accomplished by a Rotary tumbler. Did you mean, vibratory? Yes I said Rotary tumbler. but meant Vib tumbler which is faster but it will not round the rock as wiil a rotary tumbler. rocktumbler.com/rotary.shtmlTypes of rock tumblers There are two different types of rock tumblers – rotary and vibratory. Rotary tumblers are much more common and best for beginners. When most people picture a rock tumbler, they’re thinking of a rotary. This is the type of tumbler that will knock off the edges, shape, and smooth out rough rocks during the coarse grind stage. Rocks tumbled in a rotary tumbler will change shape and become rounded. Vibratory tumblers are less common with beginners and are typically used for fine polishing rocks you’ve already shaped. A vibratory tumbler will not shape your rocks like a rotary tumbler. If you just want to polish your rocks and maintain the same shape and angles, then a vibratory tumbler may be for you. The main advantage of a vibratory tumbler is that it dramatically speeds up the tumbling process for stages AFTER your rocks have been shaped (i.e., medium grind, fine grind, and polish). So while each of the four stages in a rotary tumbler can take a week on average, stages 2-4 can all be done in only one week. An ideal setup would be to buy both a rotary and vibratory tumbler.
pizzano
Member since February 2018
Post by pizzano on May 31, 2020 19:52:31 GMT -5
Yes I said Rotary tumbler. but meant Vib tumbler which is faster but it will not round the rock as wiil a rotary tumbler. rocktumbler.com/rotary.shtmlTypes of rock tumblers There are two different types of rock tumblers – rotary and vibratory. Rotary tumblers are much more common and best for beginners. When most people picture a rock tumbler, they’re thinking of a rotary. This is the type of tumbler that will knock off the edges, shape, and smooth out rough rocks during the coarse grind stage. Rocks tumbled in a rotary tumbler will change shape and become rounded. Vibratory tumblers are less common with beginners and are typically used for fine polishing rocks you’ve already shaped. A vibratory tumbler will not shape your rocks like a rotary tumbler. If you just want to polish your rocks and maintain the same shape and angles, then a vibratory tumbler may be for you. The main advantage of a vibratory tumbler is that it dramatically speeds up the tumbling process for stages AFTER your rocks have been shaped (i.e., medium grind, fine grind, and polish). So while each of the four stages in a rotary tumbler can take a week on average, stages 2-4 can all be done in only one week. An ideal setup would be to buy both a rotary and vibratory tumbler. Oh....I so wish that were true with most 7 mohs jasper & agate........
Post by taylor on May 31, 2020 20:45:41 GMT -5
Welcome! Would love to see pictures of your end product.
Prov
Member since March 2020
Post by Prov on Jun 11, 2020 15:56:33 GMT -5
Welcome from Texas!
