nik
Member since May 2019
Post by nik on Jun 15, 2020 6:24:25 GMT -5
After a failed attempt by Fedex, and a long ocean voyage, my new (older than me) Highland Park E-5 10" saw has finally arrived. It appears to be in pretty good shape, and everything is still there aside from one screw on the clamp and the brass slide rod. Sadly, the arbor bearings have just a touch of radial play, and do not give me a sense that they are long for this world. I'm curious if anyone knows what size bearing it takes. If not, I will just pull some measurements and reverse engineer from there.
I'll post some pics of it once I complete the clean up and repaint.
Post by knave on Jun 15, 2020 7:17:27 GMT -5
My Google fu failed me.
agatemaggot
Member since August 2006
Post by agatemaggot on Jun 15, 2020 7:27:16 GMT -5
Take one of the bearings to a local bearing supply shop, they can match it no problem.
Post by knave on Jun 15, 2020 7:38:22 GMT -5
I found HP sells the whole arbor kit for $79
nik
Post by nik on Jun 15, 2020 14:17:09 GMT -5
Take one of the bearings to a local bearing supply shop, they can match it no problem. Unfortunately the closest bearing shop would involve about 8 hours on a plane to get there and back.
EricD
High in the Mountains
Member since November 2019
Post by EricD on Jun 15, 2020 14:39:23 GMT -5
Slide the pulley off and you should be able to see the bearing seal which will have a brand name and part number on it. Write it down and call a bearing supply company and they will be able to cross reference it to any brand you want, and/or give you the dimensions of the bearing so you can find one if they can't.
agatemaggot
Post by agatemaggot on Jun 15, 2020 19:32:14 GMT -5
8 hours on a plane ? Where in God's name are you at ?
Post by knave on Jun 15, 2020 19:34:20 GMT -5
8 hours on a plane ? Where in God's name are you at ? He sent me my avatar cabochon from Guam, US
nik
Post by nik on Jun 15, 2020 22:50:51 GMT -5
The closest place that would likely have a decent industrial supply would be somewhere in the Philippines. There just isn't industry here. It's pretty much all tourism and military
Post by knave on Jun 15, 2020 23:11:02 GMT -5
If you get me a part number I can have it shipped to you Nik.
nik
Post by nik on Jun 16, 2020 2:59:16 GMT -5
If you get me a part number I can have it shipped to you Nik. I appreciate the offer, but now that I have it apart and have taken a few measurements,they are a really common bearing. I will be able to get them shipped directly from a multitude of sources. The arbor housing is a constant bore from end to end, so I might go with a double row or even a roller bearing on the blade end to stiffen it up a bit. If I wind up feeling spicy, I might just install a grease fitting as well.
nik
Post by nik on Jun 16, 2020 3:06:36 GMT -5
Just for anybody else that happens to be looking in the future, the bearings are 5/8 (0.625") id, 1-3/8 (1.374") od, and 11/32 (0.344") thick, but the thickness is not a critical dimension, a 1/2" wide bearing will fit without any problem.
agatemaggot
Post by agatemaggot on Jun 16, 2020 10:11:44 GMT -5
Roller business might be a good idea !
nik
Post by nik on Jun 16, 2020 16:52:13 GMT -5
$20 later, a new set of bearings is on its way. I went with a 0.5" wide bearing with a little higher load rating than the original set. The more exotic double row or roller bearing idea went out the window once I saw the prices.
nik
Post by nik on Jun 18, 2020 5:36:01 GMT -5
After a few days soak in jet fuel, and much scraping and scrubbing, the 50 something years of crusted on shmoo, paint, and rock snot have relinquished their grasp on the various bits of the saw. IMG_20200618_173251[1] by nik1924, on Flickr IMG_20200618_173307[1] by nik1924, on Flickr Depending on tomorrow's workload, it should get sprayed with a few coats of dark pearl blue that doesn't quite match the plane that it was intended for. Then it is just a matter of waiting for the new bearings and .040 MK 303 blade.
Post by Peruano on Jun 18, 2020 9:04:54 GMT -5
That should make it fly through the rocks. Why is it that clean machines seem to run better? Have you every tried slicing marine shells. You can produce some wild patterns. But wear a mask; everyone has a different story about the dangers of inhaling shell dust.
nik
Post by nik on Jun 18, 2020 19:10:20 GMT -5
That should make it fly through the rocks. Why is it that clean machines seem to run better? Have you every tried slicing marine shells. You can produce some wild patterns. But wear a mask; everyone has a different story about the dangers of inhaling shell dust. I hope it's a happy little machine after all the work that I've put in. I've only cut a handful of shells over the years, I think I just like rocks better.
nik
Post by nik on Jun 20, 2020 21:16:11 GMT -5
NDK
Post by NDK on Jun 22, 2020 8:38:32 GMT -5
This is awesome! Appreciate the info you're sharing.
Can't wait to see the pearl blue paint job ❤️
nik
Post by nik on Jun 22, 2020 18:29:50 GMT -5
This is awesome! Appreciate the info you're sharing. Can't wait to see the pearl blue paint job ❤️ Thanks. This site and its members have been an amazing source of knowledge and information for me, so I give back when I can.
