van
Member since March 2020
Post by van on Jul 9, 2020 15:19:25 GMT -5
I have a lot of small rocks varying in size from a pea to a grape. When I load them in the barrel it seems very compacted. I’m wondering if there needs to be more gaps or space between them to polish well. In the past I have added a few smaller rocks to batches of larger ones. They turn out nice but I would like to do more than a few at a time. Any thoughts?
Post by miket on Jul 9, 2020 15:46:41 GMT -5
I'm not an expert necessarily, but I think that you should be fine as long as you don't overload the barrel. About 2/3 full is the general rule- although I sometimes cram a little more in... Someone can correct me if I'm wrong. And welcome to the forum!
van
Post by van on Jul 9, 2020 17:01:30 GMT -5
Thank you, that is encouraging!!
whyofquartz
So, Africa is smaller than I expected...
Member since December 2019
Post by whyofquartz on Jul 9, 2020 17:19:49 GMT -5
welcome to the forum van! shouldn't be a Problem
Post by knave on Jul 9, 2020 18:57:18 GMT -5
A more common error would be not enough smalls. Smalls help with cushioning and you get more contact surface between rocks. Keep us posted! Good luck!
van
Post by van on Jul 10, 2020 6:05:18 GMT -5
Thank you. I will know for certain fin a few weeks.
Post by pauls on Jul 10, 2020 16:48:21 GMT -5
Welcome from Australia Van. A load of smalls will not be a problem. I have polished Garnets from pea size down to rice grain size in one batch, they worked well.
gatorflash1
Post by gatorflash1 on Jul 12, 2020 6:41:02 GMT -5
Do you have any mixed size media you can toss in with them to balance the load?
Post by Fossilman on Jul 12, 2020 9:10:39 GMT -5
No worries, start rolling them....
van
Post by van on Aug 10, 2020 12:57:50 GMT -5
Thanks to everyone for the comments and encouragement. I let the rocks tumble in stage 1 for 2 weeks. It might have been a bit too long for some but the majority of them looked great. Stage 2 tumble was 10 days. They were extremely smooth with no edges. I plan to leave them in the stage 3 prepolish for 10-14 days. So far so good. I added 1 fairly larger piece of Unikite when I started the small rock experiment, it looks amazing!! Thanks again!!!
