polaszko
Member since August 2020
Post by polaszko on Aug 21, 2020 16:14:59 GMT -5
Some of it looks definitely like chalcedony, probably you have also some cherts here, but I don't know this region enough to be sure.
Post by jasoninsd on Aug 21, 2020 16:53:47 GMT -5
If I found that center one (the top one in the middle) out while hunting for Fairburn Agates, I would've expected that to be one! It just looks like it should be!
(Maybe that's why I'm not finding any! LOL)
kozman
Member since July 2020
Post by kozman on Aug 21, 2020 17:47:28 GMT -5
If ur talking the one in the top photo I think it might be. My issue is if the rock is whole I have nothing to cut it open. I have a dremel shaft with a 1/2 diamond disk attached to my drill. :;0) I can do pebbles.
Post by jasoninsd on Aug 21, 2020 21:55:33 GMT -5
If ur talking the one in the top photo I think it might be. My issue is if the rock is whole I have nothing to cut it open. I have a dremel shaft with a 1/2 diamond disk attached to my drill. :;0) I can do pebbles. Yep. That's the one I was talking about! I've purchased a tile saw for rock-cutting (nothing massive) and I've been waiting to set it up until after I get the house sided (only because the siding is taking up half the garage!). I've got a pile of rocks just waiting to be opened!
kyoti
Member since June 2020
Post by kyoti on Aug 22, 2020 16:59:41 GMT -5
The third picture really does look like a prairie agate. You could try tumbling them as they are to see how they come out. If you don't have enough rocks of the same hardness to fill the barrel, you can always use ceramic media to fill the load. I do that with my local chert and marble that I find.
You guys are going to love the tile saw! I got an inexpensive one a month or so ago and I have so much fun with it!
kozman
Post by kozman on Aug 28, 2020 14:55:17 GMT -5
I've seen those less expensive tile saws. How do u hold the rock while cutting it? They look like the holding jig is far away from the blade.
braat
Member since December 2016
Post by braat on Aug 28, 2020 18:54:34 GMT -5
I've seen those less expensive tile saws. How do u hold the rock while cutting it? They look like the holding jig is far away from the blade. I've used a tile saw for a few years now (on my 5th or 6th blade) and I've always held the rock in my hands. Tried using gloves at first but they only got in the way and were clumsy to use so I ditched them......I use the "turbo" blades and still have all 10 fingers
kozman
Post by kozman on Aug 29, 2020 21:22:28 GMT -5
K, thank u.
gemfeller
Member since June 2011
Post by gemfeller on Aug 29, 2020 22:18:04 GMT -5
The rocks in the second image look like chert or flint to me. They appear to have sub-conchoidal fracture, not the crisp shell-like fracture of chalcedony. The texture looks a bit "sugary," if that's the right word. Chalcedony has a clear translucent quality. Post more images when you get that saw running.
kyoti
Post by kyoti on Aug 30, 2020 8:24:18 GMT -5
kozman I use big blue rubber gloves I got from Home Depot when I cut. They protect me from any toxic materials that might be in or on the rock. (Copper,lead,icky pollution from the creeks,etc.) They also have a good grip. I also use them when I do acid polishing or cleaning. As long as your saw has a Continuous Rim diamond blade, it shouldn't cut you. It's more like a sanding disk. Don't get a blade with slots cut in it. Those will slice you like a normal saw. Rookie Rockhound has some good cutting videos on youtube.
Post by rmf on Aug 30, 2020 11:01:34 GMT -5
What @polaszko said. Right on the money!
kozman
Post by kozman on Aug 30, 2020 19:47:46 GMT -5
Thanks for the identifications. I think i should not of shown so many different rocks on one post. Thanx you guys fir the saw proper operation and review. I've been known as the poster boy for industrial accidents. BTW: I was expecting a comment on the "Windows Vista" sticker on my laptop.
Post by rockpickerforever on Aug 30, 2020 20:32:43 GMT -5
Thanks for the identifications. I think i should not of shown so many different rocks on one post. Thanx you guys fir the saw proper operation and review. I've been known as the poster boy for industrial accidents. BTW: I was expecting a comment on the "Windows Vista" sticker on my laptop. Windows Vista? Pshaw, I have a Toshiba laptop running XP! Yeah, they'll no longer update it, to me, that just means no updates to screw it up anymore, lol.
