yepx
Member since August 2019
Post by yepx on Sept 13, 2020 3:26:15 GMT -5
I have a large piece of what to me looks like quartz and I used a chemical solution to get the stained dirt removed and some of the crust off as well. I got as much of it off with the solution as I could and I would like to know what Dremel attachment I can use to either remove the little bit that's left or at least smooth the crusty pieces down so they aren't so jagged/sharp.
Post by pauls on Sept 13, 2020 20:46:00 GMT -5
That looks to me to be Agate. Quartz crystals inside.
What are you planning on doing with it? If it's a shelf specimen I would leave it as is. Quite a nice specimen too by the way.
Post by Fossilman on Sept 19, 2020 9:47:08 GMT -5
Looks like seam agate with Quartz, just as Pauls said.... Not much you can do with material like that, clean it and leave it as is... Nice material though..
yepx
Post by yepx on Sept 21, 2020 21:19:04 GMT -5
That looks to me to be Agate. Quartz crystals inside. What are you planning on doing with it? If it's a shelf specimen I would leave it as is. Quite a nice specimen too by the way. Thanks, I let my OCD get the best of me. I will just shelf it then.
Post by Peruano on Sept 29, 2020 10:15:02 GMT -5
It can be slabbed/sliced up for some unusual free form pieces as well. Not every piece will make the grade, but once in awhile you will strike a winner.
ruverman56
Member since October 2020
Post by ruverman56 on Oct 15, 2020 22:07:21 GMT -5
Looks like Druzy quartz to me. Looks like a nice piece . What are your plans for it?
