singingstone48
Thanks for letting me sign up. 60 years as a mineral collector with over 5000 cataloged specimens.
Member since June 2021
Post by singingstone48 on Jun 2, 2021 22:58:04 GMT -5
Thanks for letting me join the Forum. I am a 60 year mineral collector with over 5000 cataloged specimens. I started collecting petrified wood 20 years ago and stopped when I had a couple thousand pounds. Got into agates in 2009 after marrying a rock licker/cab maker/faceter. Recently bought a vibratory tumbler and four barrels at a club auction. I have lots of little pieces of petrified wood and agate I have found or cut that needs polishing. Will be looking for tips on how to use my tumbler. Need advice on grits, sources for same, media (ceramic and others), etc.
Post by Pat on Jun 2, 2021 23:34:28 GMT -5
Welcome from California. Not a tumbler, but the experts are here. Good luck!
lordsorril
Member since April 2020
Post by lordsorril on Jun 3, 2021 5:19:59 GMT -5
Greetings, What size rotary tumblers did you acquire? Tumbling and polishing a couple thousand pounds of petrified wood is totally doable, but, is going to require a lot of grit. Depending upon your location it would be prudent to buy grit in bulk--if I had a supplier in my area I would check to see if I could avoid the shipping costs.
Post by rockjunquie on Jun 3, 2021 6:19:15 GMT -5
Welcome aboard from Virginia!
rocket
Quality slabs for quality cabs in 2022
Member since September 2020
Post by rocket on Jun 3, 2021 7:59:19 GMT -5
Welcome from Maryland
Post by hummingbirdstones on Jun 3, 2021 9:27:00 GMT -5
Hi and welcome from Northern Arizona!
You have come to the right place for tumbling advice. The Rock Tumbling Board has a plethora of information in it already, but you can always start a thread and ask any specific questions you have. Have fun!
Post by opalpyrexia on Jun 3, 2021 14:52:49 GMT -5
Welcome from Washington.
Post by jasoninsd on Jun 3, 2021 19:54:45 GMT -5
Welcome to the forum from South Dakota!
Post by drocknut on Jun 4, 2021 12:47:19 GMT -5
Welcome to the forum from south central Arizona
