Post by perkins17 on Jul 26, 2021 11:34:23 GMT -5
I was thinking of at some point purchasing some sort of lapidary equipment and was told that a flat laps would be a good affordable option. I have tried my local rock club's lap and I never got a good polish and aluminum chunks came off every time you bumped the middle. Does anyone have a good experience with flat laps? Thanks!
Post by perkins17 on Jul 26, 2021 12:12:51 GMT -5
Sorry, forgot to mention that I mean the spinning ones not the vibrating ones.
Post by rockjunquie on Jul 26, 2021 13:18:33 GMT -5
All I can say is I never really got the hang of it after starting on wheels. BUT, slews of people use them with no troubles, including my son who has mine.
rewdownunder
Member since March 2012
Post by rewdownunder on Jul 26, 2021 15:00:54 GMT -5
Which kind? the old ones that use SC grit or the new ones with diamond polishing pads. Our club has a 24" with diamond pads that is great for big flats. Clean and fast but WOW $$. They also make an 8" that is at a 45 degree slant that I have used once but I think they are still about $1000.00 by the time you get everything you need. The diamond ones are a much higher RPM so they cut quickly.
Post by victor1941 on Jul 26, 2021 15:09:19 GMT -5
I have used an Ameritool 8 inch flat lap for a number of years and had good results. The flat lap is used to shape the stone or small slab and a UV-18 vibe is used for all other steps. I started on the circular wheels and can tell you your arm/wrist position will be different, I also sometimes do heavy rock removal with a flat lap connected to the end of the circular units because I can exert heavy pressure and not damage the unit. The Ameritool unit should not be used this way because you will damage the bearing and void the warranty.
Post by perkins17 on Jul 26, 2021 16:56:25 GMT -5
Thank you! I had a lot of trouble with my club's because (I think) the plates might have been worn out. I will start to explore that as a more affordable option.
Post by Rockoonz on Jul 28, 2021 9:45:47 GMT -5
Some basic tutorials, if you have a few minutes.
