ericabelle
Instagram acct: @erica_shoots_everything
Member since April 2021
Post by ericabelle on Oct 7, 2021 17:26:58 GMT -5
Post by jasoninsd on Oct 7, 2021 18:37:08 GMT -5
Pretty cool rock! I have no clue what it is. If you're looking for a "perfect" tumbled rock, I think it might cause some problems as that fissure looks pretty deep, and it has that fracture as well. If you're ok with a tumbled rock that's NOT perfect, I'd say go for it...but you're going to need to get the grit out of that fissure after each stage...
ericabelle
Post by ericabelle on Oct 7, 2021 18:49:23 GMT -5
Pretty cool rock! I have no clue what it is. If you're looking for a "perfect" tumbled rock, I think it might cause some problems as that fissure looks pretty deep, and it has that fracture as well. If you're ok with a tumbled rock that's NOT perfect, I'd say go for it...but you're going to need to get the grit out of that fissure after each stage... Yeah, it would definitely require some extra attention at each step, that's for sure!
Post by rmf on Oct 8, 2021 8:40:31 GMT -5
the first two images show quartz with some agate. the last image looks like the other rock may be some rhyolite.
Post by jasoninsd on Oct 8, 2021 8:55:59 GMT -5
the first two images show quartz with some agate. the last image looks like the other rock may be some rhyolite. If it is rhyolite, wouldn't that undercut the quartz and agate if tumbled?
ericabelle
Post by ericabelle on Oct 8, 2021 9:16:24 GMT -5
the first two images show quartz with some agate. the last image looks like the other rock may be some rhyolite. Ok, that makes sense - I am not good at ID'ing rhyolite. It seems like it can look very different, depending on the area; so I haven't got it pegged yet!
Post by rmf on Oct 8, 2021 10:40:31 GMT -5
the first two images show quartz with some agate. the last image looks like the other rock may be some rhyolite. If it is rhyolite, wouldn't that undercut the quartz and agate if tumbled? possibly depending on quartz content
