Post by perkins17 on Oct 19, 2021 22:39:10 GMT -5
I was wondering, how long do Sic belts last with regular use and hard stones? I know there are a lot of other variables, but how many cabs do you think I could make before needing to replace them. Thanks in advance.
Post by Rockoonz on Oct 20, 2021 3:12:01 GMT -5
What grit? What size belt? If you are trying to remove material with a coarse grit belt it will become less effective fairly rapidly and maybe last 3-4 cabs. If you remove material and do most of your shaping with a hard diamond wheel or a 80/220 grit set, a 280 wheel after that could last a long time, maybe 20-30 cabs. Expect about twice as many from the 600 grit belt after that, and so on. The finer the grit, the longer it will last.
Post by knave on Oct 20, 2021 6:03:38 GMT -5
The belts I got from Kingsley North maybe did 10 cabs
Post by perkins17 on Oct 20, 2021 9:09:11 GMT -5
What grit? What size belt? If you are trying to remove material with a coarse grit belt it will become less effective fairly rapidly and maybe last 3-4 cabs. If you remove material and do most of your shaping with a hard diamond wheel or a 80/220 grit set, a 280 wheel after that could last a long time, maybe 20-30 cabs. Expect about twice as many from the 600 grit belt after that, and so on. The finer the grit, the longer it will last. Ok thanks! I will not be doing shaping on an expando unless I have super soft stuff.
Post by perkins17 on Oct 20, 2021 9:09:21 GMT -5
The belts I got from Kingsley North maybe did 10 cabs Ok thanks!
Post by jasoninsd on Oct 20, 2021 11:20:41 GMT -5
How long do belts last? Well it totally depends on how much one eats at Thanksgiving! Oftentimes a belt will have to be replaced due to size constraints! LOL *I know this wasn't exactly what you were asking about...Sorry...WAY too much coffee this morning! LOL
Post by rmf on Oct 20, 2021 14:41:56 GMT -5
I use to use 2.5" x 8" diameter belts and could get about 100 cabs on 80 grit and 220grit. I now use diamond. My older belts the glue has failed due to age. Diamond is much better. This assumes SiC 80 and 200 grits. the 400 and 600 are harder to tell I kept them around even when they were really worn out since they worked well on softer stones.
Post by perkins17 on Oct 20, 2021 18:11:45 GMT -5
I use to use 2.5" x 8" diameter belts and could get about 100 cabs on 80 grit and 220grit. I now use diamond. My older belts the glue has failed due to age. Diamond is much better. This assumes SiC 80 and 200 grits. the 400 and 600 are harder to tell I kept them around even when they were really worn out since they worked well on softer stones. Thanks! I will see about ordering some from Kingsley North today.
Post by perkins17 on Oct 20, 2021 18:12:31 GMT -5
How long do belts last? Well it totally depends on how much one eats at Thanksgiving! Oftentimes a belt will have to be replaced due to size constraints! LOL *I know this wasn't exactly what you were asking about...Sorry...WAY too much coffee this morning! LOL 😂 That IS how I feel after Thanksgiving!
Post by rmf on Oct 21, 2021 12:54:43 GMT -5
How long do belts last? Well it totally depends on how much one eats at Thanksgiving! Oftentimes a belt will have to be replaced due to size constraints! LOL Image showing Dunlapse disease. where the belly has done lapsed over the belt. I have that problem too *I know this wasn't exactly what you were asking about...Sorry...WAY too much coffee this morning! LOL
