Post by Rockoonz on Feb 14, 2022 22:20:35 GMT -5
Beacon Star Combo Machine has 6 inch 100 grit and 200 grit Silicon Carbide Hard wheels and a 6 inch x 2.5 inch wide expando drum for belts. The hard wheels can be swapped for diamond wheels if the buyer has them. It has a rag polisher on the end that was put there for turquoise. The 6" trim saw has a blade with life left in it, and a flat top that allows room to cut from larger slabs safely. It has new wiring with the switch on the 1/3 HP motor away from water spray, as it should be. It has 8 feet of drain hose ready to be set up as the buyer needs it, and water lines ready for a bucket like the one pictured or hooked to water lines. It is about ready to make some cabochons, or whatever you want to do. $550.00 cash in person in AZ just NW of Phoenix, I won't ship but I may deliver if fairly local, cost TBD.
I found this machine recently and did a fluff & buff. Cleaned it up, it was needing it. Put on a good 1/3 HP Dayton motor with new switch away from the water, and new wiring. Put it on a good plywood base. 8 feet of new drain tubing. I want to get $550 for it and I won't ship it. Of course for RTH people there would be some kind of bonus. I just put it in FB Marketplace in a couple lapidary tool sales pages and may also post on instagram. A YouTube is included, I can also email or text pics as needed. PM if interested, maybe questions here so all can see the answer if I know it.
