nursetumbler
Member since February 2022
Post by nursetumbler on May 10, 2022 7:55:00 GMT -5
brybry
Enter your message here...
Member since October 2021
Member is Online
Post by brybry on May 10, 2022 10:11:50 GMT -5
If the slab/slabs will fit i your barrels, you can tumble them. Slabs + well padded with smalls should give you some decent results. I believe a couple members on here tumble slabs.
Post by Peruano on May 10, 2022 15:47:52 GMT -5
Warning! If variscite is correct ID, it will be too soft to process w the others. Jmho
nursetumbler
Post by nursetumbler on May 10, 2022 20:15:35 GMT -5
Warning! If variscite is correct ID, it will be too soft to process w the others. Jmho I probably wont do anything with any of them as i wouldn't want to ruin them. I'm a tumbler not a slabber/cabber. I wish I knew for sure.
nursetumbler
Post by nursetumbler on May 10, 2022 20:16:19 GMT -5
Warning! If variscite is correct ID, it will be too soft to process w the others. Jmho And not a good one either
nursetumbler
Post by nursetumbler on May 10, 2022 21:05:42 GMT -5
Been told the green slab may be green malakite.
Post by jasoninsd on May 11, 2022 1:45:13 GMT -5
Been told the green slab may be green malakite. If there's a chance you can post a picture of that one wet, it might be easier to identify. Now that you say Malachite, there does appear to be an "orb" structure in the lower left portion of that slab... ETA - I forgot to mention congrats...there's some nice looking slabs in there! And by the way, I slabbed up a bunch of Mexican Royal Velvet Obsidian and I've got those running in the vibe right now. You probably have more experience tumbling than I do! LOL - If you get a chance, look up some of henryrocks (his username might be hankrocks) threads as I believe he tumbled slabs frequently.
Post by HankRocks on May 11, 2022 7:29:43 GMT -5
Been told the green slab may be green malakite. If there's a chance you can post a picture of that one wet, it might be easier to identify. Now that you say Malachite, there does appear to be an "orb" structure in the lower left portion of that slab... ETA - I forgot to mention congrats...there's some nice looking slabs in there! And by the way, I slabbed up a bunch of Mexican Royal Velvet Obsidian and I've got those running in the vibe right now. You probably have more experience tumbling than I do! LOL - If you get a chance, look up some of henryrocks (his username might be hankrocks) threads as I believe he tumbled slabs frequently. Home now, will respond with some slab-tumbling thoughts later as I get more strength back. Henry
quartzilla
Member since April 2020
Post by quartzilla on May 11, 2022 7:39:14 GMT -5
That wood is awesome!
Post by jasoninsd on May 11, 2022 8:34:34 GMT -5
If there's a chance you can post a picture of that one wet, it might be easier to identify. Now that you say Malachite, there does appear to be an "orb" structure in the lower left portion of that slab... ETA - I forgot to mention congrats...there's some nice looking slabs in there! And by the way, I slabbed up a bunch of Mexican Royal Velvet Obsidian and I've got those running in the vibe right now. You probably have more experience tumbling than I do! LOL - If you get a chance, look up some of henryrocks (his username might be hankrocks) threads as I believe he tumbled slabs frequently. Home now, will respond with some slab-tumbling thoughts later as I get more strength back. Henry I didn't want to tag you because I didn't know where things were at for you. Glad to hear you're home.
nursetumbler
Post by nursetumbler on May 11, 2022 19:31:45 GMT -5
The person that gifted me the slabs confirmed the green is malakite. He said if I work it it has to be under water? He said it has asbestos in it!?!?!?!?!?!?
PrettyGritty (Mel)
I never know what I'm doing until it's done.
Member since August 2020
Post by PrettyGritty (Mel) on May 12, 2022 11:37:54 GMT -5
Malachite is toxic if you breathe in the dust; but for tumbling, risk is very low. Just don't drink your tumbler water I would probably get it polished on a flat lap and display it, but that's me.
nursetumbler
Post by nursetumbler on May 12, 2022 22:10:11 GMT -5
Malachite is toxic if you breathe in the dust; but for tumbling, risk is very low. Just don't drink your tumbler water I would probably get it polished on a flat lap and display it, but that's me. PrettyGritty (Mel)I dont have one 😕 The man that gifted it to me said that it has or is asbestos. Drink Tumbler water? 🤔 Doesn't everyone? Guess I'll switch to coffee to tumble with then it will be safe right? 🙃
Post by jasoninsd on May 13, 2022 7:27:53 GMT -5
The person that gifted me the slabs confirmed the green is malakite. He said if I work it it has to be under water? He said it has asbestos in it!?!?!?!?!?!? There's been a lot of discussion in the past about working material such as Malachite. It's my understanding since you're tumbling it, you aren't creating any rock dust...so nothing to really worry about... "What kind of grit you using?" "Who me? Oh...I use Folgers!" LOL
Post by hummingbirdstones on May 13, 2022 9:40:05 GMT -5
The person that gifted me the slabs confirmed the green is malakite. He said if I work it it has to be under water? He said it has asbestos in it!?!?!?!?!?!? Malachite does NOT have asbestos in it. It is toxic when you cut it because of the large amount of copper in it. Breathing in copper dust is not good for your lungs. That's why it's cut with a lot of water and wearing a mask. If you were to tumble the slab, it wouldn't be something to be concerned with.
nursetumbler
Post by nursetumbler on May 13, 2022 11:38:06 GMT -5
The person that gifted me the slabs confirmed the green is malakite. He said if I work it it has to be under water? He said it has asbestos in it!?!?!?!?!?!? There's been a lot of discussion in the past about working material such as Malachite. It's my understanding since you're tumbling it, you aren't creating any rock dust...so nothing to really worry about... "What kind of grit you using?" "Who me? Oh...I use Folgers!" LOL jasoninsdI'm a Starbucks girl myself. LMHBO
nursetumbler
Post by nursetumbler on May 13, 2022 11:43:56 GMT -5
The person that gifted me the slabs confirmed the green is malakite. He said if I work it it has to be under water? He said it has asbestos in it!?!?!?!?!?!? Malachite does NOT have asbestos in it. It is toxic when you cut it because of the large amount of copper in it. Breathing in copper dust is not good for your lungs. That's why it's cut with a lot of water and wearing a mask. If you were to tumble the slab, it wouldn't be something to be concerned with. Thank you hummingbirdstones. The gentleman is in his 90's and called moonstone gypsum. Couldn't find any readings that theybwere the same so I smiled and said thank you. Could there be copper inclusions in malachite? There are a couple places in it that you can see metalic bits. He also said this had been used as Egyptian money.🤔
Post by hummingbirdstones on May 13, 2022 19:37:03 GMT -5
Malachite does NOT have asbestos in it. It is toxic when you cut it because of the large amount of copper in it. Breathing in copper dust is not good for your lungs. That's why it's cut with a lot of water and wearing a mask. If you were to tumble the slab, it wouldn't be something to be concerned with. Thank you hummingbirdstones . The gentleman is in his 90's and called moonstone gypsum. Couldn't find any readings that theybwere the same so I smiled and said thank you. Could there be copper inclusions in malachite? There are a couple places in it that you can see metalic bits. He also said this had been used as Egyptian money.🤔 Malachite is a copper mineral, just like Azurite, Chrysocholla and a host of other copper complexes. I don't recall ever seeing metallic bits in it, but that doesn't mean it can't happen. Admittedly, I haven't cut a lot of it.
nursetumbler
Post by nursetumbler on May 13, 2022 20:10:06 GMT -5
Thank you hummingbirdstones . The gentleman is in his 90's and called moonstone gypsum. Couldn't find any readings that theybwere the same so I smiled and said thank you. Could there be copper inclusions in malachite? There are a couple places in it that you can see metalic bits. He also said this had been used as Egyptian money.🤔 Malachite is a copper mineral, just like Azurite, Chrysocholla and a host of other copper complexes. I don't recall ever seeing metallic bits in it, but that doesn't mean it can't happen. Admittedly, I haven't cut a lot of it. hummingbirdstonesCan you see the little gold colored inclision near the bottom left? Thats in a few of those "holes"
Post by hummingbirdstones on May 13, 2022 20:33:44 GMT -5
Malachite is a copper mineral, just like Azurite, Chrysocholla and a host of other copper complexes. I don't recall ever seeing metallic bits in it, but that doesn't mean it can't happen. Admittedly, I haven't cut a lot of it. hummingbirdstones Can you see the little gold colored inclision near the bottom left? Thats in a few of those "holes" Yep. Didn't register as gold color on my monitor. Looked more like some light colored clay or mud to me. If it is indeed gold colored, it could be gold or some type of pyrite.
