MetaMoose
@MetaMoosehead on Twitter
Member since July 2021
Post by MetaMoose on Jun 7, 2022 16:25:42 GMT -5
Hi folks, I would like to convert an arbor housing that had drum wheels to run 1” arbor sintered wheels. The sintered wheels are the same arbor length/width as nova wheels (currently on a cabbing machine with novas in fact). I’d like to move them to this dedicated housing for grinding, but the bushing or whatever the drum wheels sat on is narrow in width, and the arbor for the sintered wheel is too wide for it. I’d need to replace parts in the arbor arm, but I’m not sure what to look for/Google. Pics here, if you could help me know what I would need, if it is possible? Thank you! imgur.com/gallery/XCQPYrxEdit: here’s the sintered wheel and a pic of it on the cabbing machine for reference. imgur.com/gallery/B2N8Evr
AzRockGeek
Member since September 2016
Post by AzRockGeek on Jun 7, 2022 16:45:40 GMT -5
MetaMoose
Post by MetaMoose on Jun 7, 2022 16:55:11 GMT -5
Thanks for the response. Maybe? I’ve loooked at those, but I’m not sure if they are wide enough? They don’t seem to list the width?
AzRockGeek
Post by AzRockGeek on Jun 7, 2022 17:02:50 GMT -5
They are typically 1" wide. I have used two before for wider wheels, you can cut them to length with a hacksaw. I seen thinner ones as well, probably about 0.5".
MetaMoose
Post by MetaMoose on Jun 7, 2022 17:06:11 GMT -5
They are typically 1" wide. I have used two before for wider wheels, you can cut them to length with a hacksaw. I seen thinner ones as well, probably about 0.5". Cool ty.
