bunnyfights
Member since May 2022
Post by bunnyfights on Jun 20, 2022 9:33:36 GMT -5
Back again for some Rock ID learning. Update - I now have a MK 370 which is prob 20 years old but seems to work well, I have fairly sizeable orange and white Jasper nodule (8x4x6). I cut the end off and it looks to me like a mix of Jasper and Agate. Parts of the cut are translucent and parts are opaque. There does seem to be orange-red banding in the mix as well. From what I have been reading the agate classification seems to be somewhat subjective. This nodule was produced within sedimentary material which seems to produce a much less predictable outcome. Thoughts? Cut: Whole Rock:
ThomasT
Trying to keep the dust down.
Member since June 2022
Post by ThomasT on Jun 20, 2022 15:51:58 GMT -5
The image appears to be a beautiful plume of agate.
Post by rockjunquie on Jun 20, 2022 18:50:47 GMT -5
Yes, likely some kind of agate, but it kinda looks like coprolite, too. RWA3006 Randy may be able to help if it is coprolite. He's the expert. Where was it found?
Post by RWA3006 on Jun 20, 2022 20:43:58 GMT -5
It does look a bit like coprolite on the inside, less on the outer surface. The big question to determine if it's coprolite is what general area it was found.
If I had to guess right now without knowing anything else I would say it's an agate, not coprolite because of the outer surface.
bunnyfights
Post by bunnyfights on Jun 21, 2022 9:03:46 GMT -5
Location was Southern WI. I have a number of other jaspers\agates from this same location. Here is one I found yesterday.
Post by rmf on Jun 21, 2022 12:43:15 GMT -5
The outside of image 2 looks like a fossilized coral. The inner part looks like the structure was not preserved. It has been my experience that cold water agates like Missouri Lace, Paint Rock/KY/Tennessee agate are softer than the Brazilian and Lake Superior agates. I get a start of a shine at 600 grit when cabbing a Laker but with the softer agates I have to get to 1200 to get the same luster. Once through the 3000 you can't tell the difference.
Image one looks like a mixture of Agate and quartz. the orange is probably from decomposed iron minerals. Pretty stuff
Post by fernwood on Jun 21, 2022 14:28:22 GMT -5
I agree. The first one looks like what I find in Central WI. Very pretty.
