muaddib
Member since July 2022
Post by muaddib on Jul 24, 2022 11:11:27 GMT -5
Hey, as I said, I'm from the UK.
Currently have 2 x NatGeo hobby tumblers that I have on constantly
Looking into getting a vibratory tumbler but by gum it's hard to get one in the UK, all amazon/ebay have is shipping from the US so add on another £80!!
Any UK users have the same trouble or do you have a UK supplier ?
I've enjoyed my lookaround so far and will continue to learn and read, nice forum btw.
The spice must flow !
Post by Starguy on Jul 24, 2022 15:35:06 GMT -5
Hi muaddib Welcome from Idaho in the US. You’re not a Frank Herbert fan by any chance? I’ve read most if not all of his books. This is a great forum for almost anything lapidary related. I’m looking forward to seeing photos of your tumbles.
Post by rockjunquie on Jul 24, 2022 16:06:40 GMT -5
Your name is a killing word!
Post by vegasjames on Jul 24, 2022 18:06:23 GMT -5
Welcome to RTH.
Post by hummingbirdstones on Jul 24, 2022 18:47:54 GMT -5
Welcome from Northern Arizona!
Post by jasoninsd on Jul 24, 2022 20:11:49 GMT -5
Welcome to the forum from South Dakota! I have GOT to see the new remake...I've been dying to see how it compares to the original.
Post by opalpyrexia on Jul 24, 2022 20:53:27 GMT -5
Welcome from Washington State. My supply of spice is almost depleted.
Post by Deleted on Jul 24, 2022 22:34:53 GMT -5
Hi from Illinois! Gabriel_GER is from Germany and might be of some help with suppliers near you.
Post by Deleted on Jul 24, 2022 22:37:58 GMT -5
Gabriel_GER
Member since May 2022
Post by Gabriel_GER on Jul 25, 2022 2:35:28 GMT -5
Hi from Illinois! Gabriel_GER is from Germany and might be of some help with suppliers near you. Hey! This it what I found regarding the UK during my adventure, trying to source stuff for myself.
More general list of suppliers:
Good luck and good hunt!
Cheers
Gabriel
Post by liveoak on Jul 25, 2022 6:19:28 GMT -5
Welcome from NW Florida
Patty
muaddib
Post by muaddib on Jul 25, 2022 6:42:44 GMT -5
Thanks for the warm welcome.
I am indeed a huge Dune fan (new movie was excellent)
Thanks for the links but alas, none of them seem to stock vibratory tumblers, annoyingly a couple of them seem to only supply the trade (ukge & beach lapidary) I'll keep searching.
Post by Starguy on Jul 25, 2022 18:02:26 GMT -5
Welcome to the forum from South Dakota! I have GOT to see the new remake...I've been dying to see how it compares to the original. Hey Jason. The new “Dune” movie is outstanding. It’s close to the book and the special effects are amazing. I can’t wait for the next one to come out. My only complaint was that the remake only covered half of the book. muaddib. Frank Herbert has a bunch of great books. “The Dosadi Experiment” is exceptional. “Destination Void” and it’s two sequels are also excellent reads.
muaddib
Post by muaddib on Jul 26, 2022 4:51:02 GMT -5
Welcome to the forum from South Dakota! I have GOT to see the new remake...I've been dying to see how it compares to the original. Hey Jason. The new “Dune” movie is outstanding. It’s close to the book and the special effects are amazing. I can’t wait for the next one to come out. My only complaint was that the remake only covered half of the book. muaddib . Frank Herbert has a bunch of great books. “The Dosadi Experiment” is exceptional. “Destination Void” and it’s two sequels are also excellent reads.
Must admit I've only done the Dune books by Frank, avoided the later ones by Kevin & Brian (his son) as advised by reddit readers.
I have read them many times with the God Emperor being my favourite of the series so I definitely check out those other 2 you mention.
As for the movie Im glad it was split into two parts, like Lord of the rings, it's too big to try and cram into 1 movie. Looking forward to the day I can sit and watch them both one after another.
Post by As I in does tries! on Jul 27, 2022 0:27:25 GMT -5
Greetings and Welcome from Scotland, I don't have any issues about getting lapidary supplies or machines, but I don't need to buy any at at the time being as I currently have two Lortone rotary tumblers the QT12/66 20kg (44.09lb) using 12lb barrel 10kg (22.04lb) using both 6lb barrels and the Commercial C300 series 60kg (132.27lb) using three 12lb barrels or 50Kg (110.23lb)using a pair of each 12lb and 6lb barrels. Lortone QT12 and QT66 Images from The Rock Shed Lortone C300 with a pair 12lb barrels a 6lb barrel and a 3lb Evans rubber barrel sitting upright between the rollers. Evans Cr2 Image from UKGE:Rock TumbleThe 3lb Beach Tumbler comes either 2x 1.5lb or 3lb plastic barrels and the Evans CR2 with two 3lb rubber barrels, both Beach and Evans tumblers are made in the UK for the UK market. I also have a pair of Viking Vibrasonic vibratory tumblers with a pair of each 6lb and a pair of 14lb hoppers too. Image from Diamond PacificIn addition I also have a 6 wheel 150mm (6 inch) Hans Lapidary Grinder and polisher, with 60 grit (F80) and 200 grit (F280) sintered wheels each weighing in at 4.7kg (10.36lb) also F600, F1200, F3000 soft wheels, plus a expando wheel with both F14,000 and F50,000 belts. I had a 3lb Beach tumbler that went to [Billyd] Montrose Scotland with a pair of Lortone 6lb rubber barrels, with grits and Aluminum Oxide polish. I also had a 6lb Evans CR2 tumbler with 2x Lortone 1.5lb rubber barrels and 2x 3lb Lortone rubber barrels with grits and Aluminum Oxide polish that went to my sister in Truro UK. All machines I have or I have had all motors run at 75°C (167°F)!
Post by Rockoonz on Jul 27, 2022 1:28:58 GMT -5
Welcome from AZ USA when I'm not on Arrakis
muaddib
Post by muaddib on Jul 28, 2022 6:27:53 GMT -5
Greetings and Welcome from Scotland, I don't have any issues about getting lapidary supplies or machines, I also have a pair of Viking Vibrasonic vibratory tumblers with a pair of each 6lb and a pair of 14lb hoppers too.
That's all good to know I guess.
I have no problems in purchasing barrelled tumblers in the UK, it's the vibratory ones that seem to be completely missing from these isles.
Where'd you get those Viking vibrasonics from if you don't mind me asking.
Post by As I in does tries! on Jul 29, 2022 4:45:19 GMT -5
I bought them both about 10 years ago second hand and one of them is 48 and the other is 50 years old this year, however it was around 250 mile round trip, the units cost £80 and another £80 costs as I don't drive myself. Your options are import new from the EU, Raytech TV5 3lb Gabriel got one recently above, 10lb Spirlator or import from the USA, Belt Lotto, Raytech, Diamond Pacific, I have never seen any Thumlers tumblers with 220v/50hz motors, just 110v/60hz motors for continental North America, or like me hope you can find one second hand; see Lapidary Vendors Worldwide.
Post by drocknut on Jul 29, 2022 14:18:27 GMT -5
Welcome to the forum from south central Arizona
