RocKingRuralMo
Member since July 2022
Post by RocKingRuralMo on Aug 6, 2022 13:12:58 GMT -5
I sprung for a new blade (Covington gold) for my 1960s weight-fed 16 inch rock saw. I'd done some other refurb on it and it has done decent work. (Have only had it for a month.)
While I had the blade off (and was waiting for a new one to arrive) I pulled and replaced the bearings (badly needed), changed the belt, etc.. Now I'm struggling to get the blade running true again.
I've cleaned behind the stabilizers, I've adjusted, readjusted, and cussed at the bearing housing, but I'm getting some weird lateral travel on my blade. I've had the thing off and back on again in a dozen different configurations (different washers, different stabilizers, etc.) but just can't seem to get it running right. I checked the blade on a level workbench, and it's not warped even though it looks like it in the videos.
This imgur link (below) has a video and some photos. Would love expert input if you're willing to offer it.
Post by quartz on Aug 6, 2022 21:50:59 GMT -5
Do you have or can borrow a dial indicator to check to see if the inside saw collar is running true, probably the best first place to start looking. Assuming the blade is flat.
brybry
Enter your message here...
Member since October 2021
Post by brybry on Aug 7, 2022 10:04:15 GMT -5
Did you buy a factory spec blade or a discount out of round blade? The gold series are sold both ways. You may gotten a discount blade. Will still cut but isn't within factory specs for true.
Post by liveoak on Aug 7, 2022 10:20:58 GMT -5
Did the old blade run true ?
You might try swapping the inside to outside stabilizers. You can also mark the blade with a marker, & try rotating it to different positions on the arbor. You might hit a sweet spot where it runs true.
Patty
Post by Rockoonz on Aug 7, 2022 10:46:13 GMT -5
Is there a flange on the nut side? maybe it's just the camera angle, but if you don't have equal sized flanges on both sides tightening the blade will dish it. You also don't need to do more tha a good and snug when tightening the blade nut.
RocKingRuralMo
Post by RocKingRuralMo on Aug 7, 2022 13:45:40 GMT -5
Do you have or can borrow a dial indicator to check to see if the inside saw collar is running true, probably the best first place to start looking. Assuming the blade is flat. Borrowed one this morning! Thank You!
RocKingRuralMo
Post by RocKingRuralMo on Aug 7, 2022 13:47:55 GMT -5
Did the old blade run true ? You might try swapping the inside to outside stabilizers. You can also mark the blade with a marker, & try rotating it to different positions on the arbor. You might hit a sweet spot where it runs true. Patty Thanks so much for your reply! The old blade definitely did not run true. It would run, and it would cut, but it left a kerf way wider than the blade. But it also didn't check out as level. The new blade is (if my worktable and spirit level can be trusted) testing level. I'll try the rotating strategy. Many thanks!
