Post by parfive on Mar 26, 2024 19:28:06 GMT -5
Metric colors, eh? : )
Yellow/green is the ground, blue is the neutral and brown connects to the hot leg.
chris1956
Member since July 2022
Post by chris1956 on Mar 26, 2024 19:34:08 GMT -5
I'm in the process of replacing the motor of my double Lot-O. The motor I ordered was supposedly branded Bizoepro (what my order said, but no name on the motor-probably coming from the same factory) and appears the same as in the photos of the previous build (The Rock Shed?). This motor has four wires coming from the motor (yellow/green stripe, blue, brown, and black) into a plastic box (capacitor?), with three wires coming out of that box (yellow/green stripe, blue and brown) for a plug. I know nothing about Chinese wiring colors, so....if anyone has completed this mod, how did you wire the plug? I went with the concrete vibratory motor for the replacement motor. The wiring matched up with standard plug. I am sure there is somebody out there that will know the answer. It does make me mad that the manufacturers for a lot of the products now coming from China don't even put their names on their products. Makes me think they don't want to here from anyone if something goes wrong.
Post by southernlakehuronguy on Mar 28, 2024 11:02:22 GMT -5
Just as parfive said,yellow/ green wire to ground (green), blue to neutral(white) and brown to hot(black). Screw on plug for hot will actually be brass colored. Neutral on plug will be silver and ground will be green.
