chris1956
Member since July 2022
Post by chris1956 on Apr 16, 2023 11:28:18 GMT -5
Do you think more water would help or hurt with the triangular shape? I get a lot of them also. I am going to try the marbles and see what happens to them.
rockbrain
Member since January 2022
Post by rockbrain on Apr 16, 2023 12:10:20 GMT -5
Is anyone getting triangular shape with barrels that are round inside? If I remember correctly when I put marbles in the 3lb Lorteone barrels they just get smaller. I think it might just be the ones that are octagon shape inside. Going off my memory is not always the safest bet!
pebblesky
Member since September 2022
Post by pebblesky on Apr 16, 2023 12:34:51 GMT -5
These guys are worn down real small. They're about 3/8 of an inch on a large dimension. The marble with them in this picture is a standard size. What they all started off as That's interesting!
Post by stefan on Apr 16, 2023 13:19:22 GMT -5
I was going to make some obscure reference to the way a rotary engine works, but I got to thinking that perhaps it just has to do with the micro crystalline structure of the silica material being tumbled. Very interesting dilemma.
chris1956
Post by chris1956 on Apr 16, 2023 17:07:52 GMT -5
Is anyone getting triangular shape with barrels that are round inside? If I remember correctly when I put marbles in the 3lb Lorteone barrels they just get smaller. I think it might just be the ones that are octagon shape inside. Going off my memory is not always the safest bet! Mine are octagon shape. Hmmm...
Post by Lazy Perfectionist on Apr 17, 2023 13:44:16 GMT -5
My guess would be material prone to conchoidal fractures. I've seen several duck heads appear in my first batches of tumbled obsidian.
chris1956
Post by chris1956 on Apr 17, 2023 18:56:56 GMT -5
These guys are worn down real small. They're about 3/8 of an inch on a large dimension. The marble with them in this picture is a standard size. What they all started off as Well, I guess I am no Sherlock Holmes when it comes to observation and memory. I emptied my 3 and 12 pound Lortone barrels today and noticed that the 3 pounder is round with 6 semi-circular ridges the length of the barrel and the 12 pounder is not octagonal but has 10 sides on the inside. Now, I guess I am going to have to dig up some marbles and put them in both barrels and see if there is any difference. How long did it take you to deform the marbles to the duck bill state?
rockbrain
Post by rockbrain on Apr 17, 2023 20:24:08 GMT -5
I don't really know.
Post by stefan on Apr 22, 2023 8:32:35 GMT -5
More food for thought. This is the Lid from my 12 Lb Thumler's barrel. I see a pattern here.
Post by stefan on Apr 22, 2023 8:35:40 GMT -5
And no it is not worn thru. I glued a sheet of 1/4" acrylic over the original lid when it wore thru. I coated it in flex seal (which is wearing off after 5 years of 60/90 grinding). The acrylic is probably worn about 1/3 of the way.
Post by 1dave on May 1, 2023 14:19:21 GMT -5
The answer is obvious! No, I don't know what that means either, but I was thinking about Sand Dunes. Wind blows around the edges and heavily down the middle, Perhaps something like that is happening?
Wooferhound
Lortone QT66 and 3A
Member since December 2016
Post by Wooferhound on May 28, 2023 18:29:37 GMT -5
I was using some glass Marbles as tumbling media and noticed that some of them were getting flat on one side.
Figure what is happening is they are getting stuck on one end, or they are getting stuck in some resonate tumble action where they are repeating a cyclic motion over and over in the barrel.
So everyday I take the barrels off the tumblers and flip them end-over-end a few times to help prevent this from happening. Almost everytime I do this, the sound of the tumbling changes.
Haven't used marbles in awhile, so I really don't know if it's truly working.
mgroothuis
Member since November 2022
Post by mgroothuis on May 30, 2023 8:08:58 GMT -5
That's a great idea...flipping the barrels during the tumble. As random as tumbling rocks are, I'm sure there is a bit of a pattern that forms when they are constantly flipping in the same barrel position against the same rocks.
