Post by liveoak on Jul 14, 2023 18:05:15 GMT -5
Cutting is relatively fast - IF the blade is reasonably fresh, & the guides are adjusted correctly.
Difference is that with the bandsaw, you're not just getting CLOSE to the size/shape, you're cutting the exact size/shape, so it also speeds up work later.
And yes, you're not wasting valuable slab real estate. Which in my case, with my somewhat limited supply, is important.
It just takes a little engineering to get the drip set up - I have mine dripping on the side of the blade above the top guide.
Alright guys - I'll take some photos in the morning of my lock line set up, & primitive drip.
But I'll tell you right now, there's no rocket science involved.
So if you're willing to fuss a little - it's a reasonable way to go.
As I said $ for $ the Inland might not to too far out of line cost wise - although it uses a special blade, & not sure of cheap knock offs for that.
I've never used one or even seen one- but they are a good deal smaller.
Thanks for the tip on the cheaper blade - I'd appreciate the source you found, I think I'll order one
I'll tag you tomorrow, as well as the others who mentioned interest.
Thanks,
Patty
rockbrain
Member since January 2022
Post by rockbrain on Jul 14, 2023 22:49:46 GMT -5
liveoak I just followed the blade link from your other post then copied and pasted the description minus the brand name in another Ebay search. Blade There's actually a few others if you do the search like that. The other listings have shipping and end up being a few bucks more.
