herb
Post by herb on Aug 30, 2023 11:20:07 GMT -5
After looking at my Raybrite stuff, the Iolox is kind of gray and powdery. The TL is really fine white powder, similar to baking soda so I think that’s what your mystery container may be! Well, it looks like you won the Identify the Mystery White Powder contest! I tried it for the polish stage in my Lot-O. Ran it for 2 days and did the clean out this morning. I would call the results polished-ish. Not a perfect polish, but pretty shiny. I think the mix might have been a little too dry because when I dumped out the barrel I saw all the small ceramic media was gathered in the bottom in a loose clump. Reloaded and am going to run for another 2 days keeping a better eye on things and see if the polish improves. I also got to try out the jar of Levigated Alumina that I mentioned in another thread. Looks like it is definitely a pre polish. Went from 400 grit SiC to the levigated alumina and the results looked about like with 1000 grit SiC. Although now that I typed this I guess it doesnt necessarily prove it is pre polish. Could be polish since I dont know how shiny a rock would be if you go directly from 400 to polish. I guess next time I'll throw a polished piece in to see if it dulls down to the pre polished look.
Post by Mel on Aug 30, 2023 18:27:35 GMT -5
Glad to be of service! That TL polished better than anything else I've used (besides the cerium & flat lap combo!) BUT I also only used it in the vibe. I'll try some in my rotary and see if I still think it's so great.
Your suspected pre-polish sounds like a definite pre-polish to me; I use a 1200 aluminum oxide as pre-polish after a round of 600 grit silicon carbide. It does a great job but man it sticks in every tiny little crack and cranny.
