Post by realrockhound on Dec 23, 2023 0:56:49 GMT -5
Oh I have a few pieces that look similar. Is the below fire obsidian then? That first one appears to have fire.
choochoorocks
Rock hounding
Member since April 2020
Post by choochoorocks on Dec 23, 2023 1:11:59 GMT -5
Good to know that -- I had it sitting in an almost-forgotten box. Might have a few more in that box.
I'm going away on a road trip (Cady for the first time) soon so the cutting of that initial piece will have to wait till I get back next year.
jasperfanatic
Post by jasperfanatic on Dec 28, 2023 18:23:14 GMT -5
I recently acquired a piece of what looks to be fire obsidian. At the moment, only a small area of fire is visible. I'd like to expose the whole layer to create a polished display piece. How should I go about cutting this? I think I can guess the direction of the layer. Should I cut parallel to and above the layer, leaving lots of buffer? But I'm not sure if there could be additional hidden layers that I may cut through? Or what if I'm misjudging the direction of the layer? Thanks for any insight! I've never actually cut obsidian! realrockhound is correct, the original images you posted are fracture fire, just the prismatic effect from the fracture and it will disappear as you grind around on it (or the piece will just break into pieces altogether). The other piece you posted is technically gold sheen, but it often has layers of lower grade fire in it, mixed with the gold sheen and mahogany - still very cool stuff. As some have alluded to, the layers are very thin. In my experience, the really good stuff has white/blue-ish lines, but some times the yellow ribbon and red ribbon stuff can be very hot. If the layers are gray-ish or not very defined, it could be low grade fire, but typically isn't worth chasing too far in my opinion (except as a practice piece) You never know what you're going to run into. The layers can be crazy and flowing all over the place, and other times you get lucky and they're mostly flat and spaced apart. The stuff can make you pull your hair out, but the reward you get from a good chunk keeps me chasing Here are a couple of examples, one with crazy layers all over, and another with flat white-ish/blue-ish layers, just as a reference. It's tough to throw this stuff into a regular slab saw, there's usually not enough space between layers for a blade to fit and you'll likely kill something beautiful lol. Most of the time I use a Gryphon glass band saw to isolate layers, but even then it's tough to thread the blade between layers and swearing soon follows. Have fun with it! \ www.instagram.com/p/CrZq4O_NB2S/
Post by realrockhound on Dec 28, 2023 18:40:16 GMT -5
I recently acquired a piece of what looks to be fire obsidian. At the moment, only a small area of fire is visible. I'd like to expose the whole layer to create a polished display piece. How should I go about cutting this? I think I can guess the direction of the layer. Should I cut parallel to and above the layer, leaving lots of buffer? But I'm not sure if there could be additional hidden layers that I may cut through? Or what if I'm misjudging the direction of the layer? Thanks for any insight! I've never actually cut obsidian! realrockhound is correct, the original images you posted are fracture fire, just the prismatic effect from the fracture and it will disappear as you grind around on it (or the piece will just break into pieces altogether). The other piece you posted is technically gold sheen, but it often has layers of lower grade fire in it, mixed with the gold sheen and mahogany - still very cool stuff. As some have alluded to, the layers are very thin. In my experience, the really good stuff has white/blue-ish lines, but some times the yellow ribbon and red ribbon stuff can be very hot. If the layers are gray-ish or not very defined, it could be low grade fire, but typically isn't worth chasing too far in my opinion (except as a practice piece) You never know what you're going to run into. The layers can be crazy and flowing all over the place, and other times you get lucky and they're mostly flat and spaced apart. The stuff can make you pull your hair out, but the reward you get from a good chunk keeps me chasing Here are a couple of examples, one with crazy layers all over, and another with flat white-ish/blue-ish layers, just as a reference. It's tough to throw this stuff into a regular slab saw, there's usually not enough space between layers for a blade to fit and you'll likely kill something beautiful lol. Most of the time I use a Gryphon glass band saw to isolate layers, but even then it's tough to thread the blade between layers and swearing soon follows. Have fun with it! \ www.instagram.com/p/CrZq4O_NB2S/ Gosh ain’t that the truth. I love end results. But have definitely lost my mind trying to process some material. I accidentally cut through a nice bar while trying to isolate the bars and literally rage quit. Later followed by grief at what I had just done. Part of the reason I’ve hardly worked the stuff I do have.
