Post by NatureNut on May 20, 2013 18:53:18 GMT -5
This wouldn't be a graduation present for her, would it? What are the walls gonna be?
Post by Bikerrandy on May 20, 2013 19:25:47 GMT -5
Walls are poly also. Not sure how long it will last, just an experiment mainly. For what I invested in it, it'll be worth it.
Post by Bikerrandy on May 20, 2013 19:33:36 GMT -5
Here's my backyard, plenty of shade....
Post by kk on May 20, 2013 19:58:19 GMT -5
Love the big trees in the yard. Its astonishing how good you all are in crating all sorts of things. ![:)](//storage.proboards.com/forum/images/smiley/smiley.png) One thing though: when fully done up, you don't need a hurricane to come through to get it flying. So how do you secure it to the ground?
Post by Bikerrandy on May 20, 2013 20:09:46 GMT -5
I'll be driving steel posts into the ground and chaining at each corner. I have a little more work to do first. I decided that I've gotta slide pressure treated 2x4's under the bottom plate to get the white pine off the ground, that stuff won't last long down there. I'm also gonna dump a truckload of gravel under the entire enclosure.
snuffy
Member since May 2009
Post by snuffy on May 20, 2013 20:18:34 GMT -5
I'll be driving steel posts into the ground and chaining at each corner. I have a little more work to do first. I decided that I've gotta slide pressure treated 2x4's under the bottom plate to get the white pine off the ground, that stuff won't last long down there. I'm also gonna dump a truckload of gravel under the entire enclosure. Good.I was wondering about the lumber sitting on the ground Was gonna recommend that or letting it sit on 4 inch hadite blocks to get it off the ground.Just didn't want to seem nosy! ;D snuffy
Post by Bikerrandy on May 20, 2013 20:21:56 GMT -5
Be nosy! lol... I don't always think of everything so I always take any info that I can get. This one was sort of easy for me though since I frame houses and some commercial framing as well, but I am forgetful sometimes. ;D
snuffy
Post by snuffy on May 20, 2013 20:31:28 GMT -5
I'd also use a strip of felt paper between the treated and regular wood as a moisture barrier too. I use cedar 2x4's in situations like this,mainly because I got a bunch from a job they were gonna throw away. ;D
snuffy
Post by helens on May 20, 2013 22:02:38 GMT -5
Well, how they handle posts in Florida is to dig footers that you fill with concrete, then you can sink the posts in there to your pre-marked levels on the posts.
Alternatively, you could dig 6" diameter post holes, fill them with concrete, level them and use those square bracket things on the bottom of each post and bolt it to the concrete.
I'm not sure how you moisture/insect barrier the bottom of the posts tho...
