Post by Pat on Feb 10, 2014 18:28:03 GMT -5
miander said she would like to see my photo setup. Here it is. The big thing in the back is the softbox with one big daylight bulb in it. The other two smaller lamps also have daylight bulbs. The entire setup takes up a little less than 3 feet by 3 feet. I can raise or lower the softbox, and I put filters (frosty paper) on the two smaller lamps. The softbox came with a velcro filter which I leave on. The item in the back, about the center of the photo, is a light panel. The entire panel gives the same amount of light. This is good for transparent items. IMG_0611 by Pat6489, on Flickr This second photo is a closeup so you can see the suspended big filter. It is always there, but I can change its position by adjusting the string. String is attached to ceiling hooks, and on hooks on the wooden frame. The filter needs to be taut so it does not create shadows in the photo. Clipped onto the softbox is is an opaque black poster board. I cut the bottom off to allow some light for gradient shots. At the corner of the table is a shiny silver card I use for reflecting light when shooting shots of metal. Makes a difference. On the right front of the table is dental wax I use to prop up various pieces. It is translucent white, but still shows up in photos unless I am very careful. I also use a makeup brush to brush away dust, Windex and rag to wipe away finger prints. I use shiny black acrylic for some photos. It's a nifty little studio about five feet from my computer. IMG_0610desk by Pat6489, on Flickr Pat
Post by pghram on Feb 10, 2014 23:00:49 GMT -5
Nice set up.
Rich
MrCoffee
Member since December 2005
Post by MrCoffee on Feb 10, 2014 23:12:41 GMT -5
I guess I'm gonna have to save up.
Member is Online
Post by jamesp on Feb 10, 2014 23:30:23 GMT -5
My light box has my collection in it. ha. When the sun gets overhead i get cool photos in the greenhouse.
GeorgeStoneStore
Post by GeorgeStoneStore on Feb 11, 2014 2:00:11 GMT -5
Pat Perfect! Light source? ( type, watt, etc ) jamesp Good idea! only in the summer is very hot
Member is Online
Post by jamesp on Feb 11, 2014 8:31:24 GMT -5
Pat Perfect! Light source? ( type, watt, etc ) jamesp Good idea! only in the summer is very hot Yes George, very hot in summer. Winter, if 20F outside, then 70-80F inside. Nice for winter.
miander
Searching for the shop of my dreams...
Member since November 2013
Post by miander on Feb 11, 2014 22:37:43 GMT -5
That is quite some set up Pat, thanks so much for taking the time to post the pictures and explain what you did!
Post by Pat on Feb 12, 2014 12:18:18 GMT -5
@georgestonestore This is what I have: www.adorama.com/FPSSBK.html, plus I bought two side lamps. Side bulbs are pigtailed Greenlites 12 volts, 5000k. The lamp shade is matte silver inside. Softbox bulb is Flashpoint SoftBox, 70 watt Fluorescent Light Unit with Built in 19.5x27.5" Silver Soft Box, with AC Plug and Spiral Fluorescent 5500K Bulb (translates into 350watt) Bundle - with Flashpoint tall Light Stand. Bulb is a very big pigtail.
Post by Deleted on Feb 12, 2014 12:58:40 GMT -5
Sweet. Reminds me of my photography school days. Jim
GeorgeStoneStore
Post by GeorgeStoneStore on Feb 12, 2014 13:20:25 GMT -5
Good configuration. I also wanted 5000-5500K bulb, but unfortunately I could not purchase power 23W. So I have 6500K. It's a bit "cold" light but still adequate. The ideal value of 5000 - 6500K between
Post by 1dave on Feb 12, 2014 13:56:44 GMT -5
jamesp what material do you use on your greenhouse that the wind and weather doesn't rip and shatter?
Member is Online
Post by jamesp on Feb 12, 2014 15:12:21 GMT -5
jamesp what material do you use on your greenhouse that the wind and weather doesn't rip and shatter? Dave, that is usually 5 year plastic and is three 2 mil layers laminated. Radiation, strength and drip proof each i think. That quonset structure is rated to 140 MPH with plastic. The house is built to 92 or 96 feet long to accommodate the 100 foot standard length plastic. It is a standard green industry plastic. That one was 100 X 40 and cost about $200. I use 1 year 4 mil for short crops. Almost 1/2 as expensive. It can be 20F and very windy. Inside easily 75F on a sunny day. The tumblers never freeze and the rocks never get leaf litter in them. A 20' X 40" would do real well my rock stuff.
Post by rockpickerforever on Feb 12, 2014 15:18:57 GMT -5
James, how well does it hold up under a ton of ice?
Post by 1dave on Feb 12, 2014 15:35:18 GMT -5
Member is Online
Post by jamesp on Feb 12, 2014 15:43:19 GMT -5
James, how well does it hold up under a ton of ice? Because of the design, surprisingly well. The angle is such that the ice slips off close to the edge. I forgot one year and left the shade cloth on. The snow stuck on it full width and it crushed it. So live and learn....
Member is Online
Post by jamesp on Feb 12, 2014 15:53:28 GMT -5
That way they will sell more. dang it man. Best to use pipes galvanized for the purpose. Those houses are cheap. This was 2 weeks ago w/four inches of snow.
Post by Deleted on Feb 12, 2014 16:55:56 GMT -5
I wonder if I could take that apart, tie it down on my travel trailer then set it up at my next location with my travel trailer and Pat's photo setup inside? Jim
Member is Online
Post by jamesp on Feb 12, 2014 18:13:21 GMT -5
If you have enough propane you can do anything Jim. I have an excess of methane. But i don't get very far on it. Where are you now?
Post by Deleted on Feb 16, 2014 10:52:52 GMT -5
I am still three miles south of Quartzsite. I have been keeping Tony company but he is leaving tomorrow or the next day so I may roll up to Lake Havashoe (sp). I have dried out like a grape down here. Jim
Post by Deleted on Feb 17, 2014 23:41:07 GMT -5
I am still three miles south of Quartzsite. I have been keeping Tony company but he is leaving tomorrow or the next day so I may roll up to Lake Havashoe (sp). I have dried out like a grape down here. Jim Haha! Wampidy brand raisins!!
