Post by rockpickerforever on Feb 25, 2020 16:02:23 GMT -5
I can't see his face, or hear his name without thinking of his Mighty Mouse skit. (Thumbs down.) His best years were when he was on Taxi.
Post by 1dave on Feb 26, 2020 16:32:11 GMT -5
Post by knave on Feb 26, 2020 19:58:55 GMT -5
Stuff and things.... yep here goes. Blast from the past. I'm getting just as good results with the unscreened in the homemade rotary, ao-80, to ao polish in the vibe as I did with the 4 step process. the only difference is I'm not running all mohs 7 stuff. the hardest stuff comes out great. 85 to 90 percent of the load on average comes out of polish looking finished. the other 10 to 15 percent Ive been setting aside till I get enough to fill my ar-12 barrel. mostly slag glass which I found polishes better in the rotary than the vibe, but unfortunately is about the only thing I find locally which is even hard enough to take a polish. thanks for the offer james but I don't really need the sic 500. like you I'm cutting out the excessive cleanouts. I'm not sure if my unscreened sic is cutting faster or not than the 30 grit (never loaded a barrel with each with new rough to do a head to head compairison). but its free grit and seems to be working well. when I went from the sic 30ish stuff to the unscreened I also went to the vibe and using more broken rough and doing less rounding and more just passing it through when the edges were knocked off and pit free for a different look. at the same time I added 2 more coarse barrels and am pulling 10 lbs out of coarse a week compared to the 3lbs I was sending through to polish to the small rotaries. I changed to many variables at once to get a good comparison. The unscreened SiC is real interesting. A grit salesman gave me SiC 8 and Sic 16. It is not much different than SiC 30. Breaks down due to SiC's brittle behavior. I think you could put 1/2" chunks of SiC in a tumbler and it would simply break down and shape your rocks. Think your unscreened SiC with +/- 30 grit particles is perfect since it can probably be had way cheaper. Screening takes a lot of effort. Yes, you get it for free. But us civilians can probably buy it way cheaper than screened. do the same darn job. Probably only available in bulk. Hell, I have purchased over a dozen 50 pound lots of coarse SIC. Bet a 2000 pound palet of unscreened is cheaper. Bet ya. Always was curious if there was bulk SiC for cheap. Your tumblers will process it. Never tried AO 80 on softer stuff. Probably not a good idea. Soft does best with 80-220-500-1000-14,000. But I gave up on soft. No telling how many runs AO 80 at this point(on Mohs 7). It has just become a routine, no variables. Predictable/repeatable blah blah.(wish I knew then what I know now...)
Post by jamesp on Feb 27, 2020 9:56:28 GMT -5
John notjustone worked in a metal melting operation knave. He was allowed to sweep up Carbolon raw SiC that spills and take it home for rock tumbling. Maybe it could not be used for remelt after it was contaminated by spilling on the floor. His feedback came in handy.
Post by jamesp on Feb 27, 2020 9:58:19 GMT -5
That looks like an Idaho State Patrol Car 1dave. They looked like a space age craft heavily out fitted.
Post by knave on Feb 27, 2020 14:49:13 GMT -5
Never check out groceries again
Post by 1dave on Feb 29, 2020 17:13:22 GMT -5
Post by knave on Mar 1, 2020 11:34:39 GMT -5
ugh 😑 Wisconsin got left in my pocket and took a ride in the dryer. Lost his thumb.
Post by 1dave on Mar 2, 2020 10:22:46 GMT -5
Post by 1dave on Mar 9, 2020 19:10:01 GMT -5
jamesp If you would just do this you could get so much more done!
Post by 1dave on Mar 9, 2020 19:26:59 GMT -5
Post by mohs on Mar 9, 2020 19:47:32 GMT -5
thumbs up to the camel don't need no prickly pear sweets bad for the molars
Post by Pat on Mar 9, 2020 19:57:42 GMT -5
We’ve had two cats who liked to chew on prickly plants!! Didn’t seem to hurt them. Ouch!! Tough little buggers!
Post by 1dave on Mar 9, 2020 20:41:18 GMT -5
Post by 1dave on Mar 9, 2020 21:08:11 GMT -5
Post by 1dave on Mar 19, 2020 13:23:53 GMT -5
Post by 1dave on Mar 20, 2020 14:09:56 GMT -5
Post by 1dave on Mar 22, 2020 21:43:16 GMT -5
Post by 1dave on Mar 24, 2020 12:53:01 GMT -5
Post by 1dave on Apr 11, 2020 16:54:01 GMT -5
The Las Vegas Story.
