Post by jamesp on Sept 28, 2016 20:00:45 GMT -5
I just ordered that beast above. It is used to wallow out core drilled holes in granite counter tops. 20 grit, beaver teeth. LOL, two Chihuahuas almost ran captbob off. However he does have an arsenal. He did qualify that, "somedays". Bet that will really chew up rocks. I like the idea about mounting it horizontal. If it grabs a rock it would launch it into the ground (might bounce so watch the twig & berries) or the next county. Are these bits sintered? High or low RPMs? Sintered and made for high RPM and high pressure. Cups are drilled for cooling. Designed for 3 HP hand grinders and extreme pressure. Holding a rock against them is pretty much negligent. Small work for what they are designed for. He has resin filled ones. That means resin is cast between the segments so that the face is continuos. Making a much slower and less aggressive grind. I ordered the one without the resin. He said try it. If I don't like it he will send the other one. As if to find what works for our hobby. Yes Garage Rocker, he would be good President. His communication skills eliminated the China communication problem.
Post by jamesp on Sept 28, 2016 20:05:57 GMT -5
Living next door would probably not be good for my marriage. Figure I'd get into more trouble in a day (frequently) than I do around here in a year! Need to take a picture of the tractor PTO powered arrowhead digger. Digs and sifts Florida sand like a potato digger.
Post by Pat on Sept 28, 2016 22:32:03 GMT -5
MrMike I like your clever solution. No clue about jamesp ideas.
Post by jamesp on Sept 29, 2016 4:26:54 GMT -5
MrMike I like your clever solution. No clue about jamesp ideas. My relatives Pat.(excessive brain disturbance)
Post by MrMike on Sept 29, 2016 4:58:40 GMT -5
MrMike I like your clever solution. No clue about jamesp ideas. My relatives Pat.(excessive brain disturbance) Creepy, disturbing yet hard to look away... Here's a reference that won't scare the children:
Post by MrMike on Sept 29, 2016 4:59:43 GMT -5
MrMike I like your clever solution. No clue about jamesp ideas. Thank you ma'am
Post by jamesp on Sept 29, 2016 5:37:49 GMT -5
LOL
Post by Deleted on Oct 1, 2016 20:42:18 GMT -5
Thread of the week!
