doublet83
Member since March 2016
Post by doublet83 on May 21, 2017 22:27:04 GMT -5
Post by quartz on May 21, 2017 23:01:53 GMT -5
zarguy, we were given a 3lb. Thumlers by an old friend, lid retaining ring missing. I went to our local auto/industrial supply and got a 1/4" [nominal] diameter o-ring that just fits down inside the barrel, I call it a "slip fit", doesn't fall in but free to slide in. It has worked fine for years. Did I record the size, no, 20/20 hindsight.
gpowers66
Member since March 2020
Post by gpowers66 on Mar 17, 2020 22:23:45 GMT -5
Hello. I recently purchased a used Thumler AR-2. It came with some off brand belts. I've gone through 4 or 5 of them in less than a week. I'm interested in the ones from the O Ring store as described above. The confusing this is that the recommended model (E70343) has a diameter size of 3-3/4"ID X 4-1/8"OD. I measured the belts that came with mine and they are 2-7/8 ID and 3-1/8 OD. Can someone please help me to understand this difference in size. Thanks. The belt they sell which you will want for your Tumbler's tumbler is model E70343 technical name - 343 E70 EPDM O-ring - 70 Duro - FDA - Black (whatever!) www.theoringstore.com/index.php?main_page=advanced_search_result&search_in_description=1&zenid=1fceb774ef6e8a886160ec110ad8502c&keyword=E70343
sisyphus
Post by sisyphus on Mar 24, 2020 10:54:13 GMT -5
I'm just a noobie here, but I did stumble onto something useful. My model 'T' pulley wobbled excessively and cannot be straightened out. My Lortone 3a uses the same diameter shaft. I poked around the parts pages at the Rock Shed, and realized that the Lortone 33b pulley and belt might work. I ordered them, and they do work very well. All that is needed is to adjust the motor to tighten the belt slightly.
Post by knave on Mar 24, 2020 10:57:01 GMT -5
Great find! You can also use cogged belts and pulleys, 3D printer parts. pioneered by EricD $10 includes both pulleys and a cogged belt.
Mark K
Member since April 2012
Post by Mark K on Feb 27, 2023 21:14:13 GMT -5
Well, I just ordered 30 of them.
