Post by captbob on Mar 2, 2017 12:08:51 GMT -5
Now I'm scared! You need AO polish which is typically 14,000 Tough finding AO after 1000. Think James found an AO 5,000 awhile back, don't recall where. jamesp ? Going from 1000 to polish should do ya fine. ETA: get AP polish anywhere, Rock Shed is where I get small grit/polish amounts. Kingsley North for bulk.
Post by melhill1659 on Mar 2, 2017 12:16:34 GMT -5
And it's level!!!
Post by captbob on Mar 2, 2017 12:26:15 GMT -5
Do you have ceramic media? I'm no Lot-O user, but I recall them folks use small ceramics as filler. Rock Shed has that too. Jugglerguy Drummond Island Rocks <-- can't tag Chuck
Post by Drummond Island Rocks on Mar 2, 2017 12:39:51 GMT -5
Do you have ceramic media? I'm no Lot-O user, but I recall them folks use small ceramics as filler. Rock Shed has that too. Jugglerguy Drummond Island Rocks <-- can't tag Chuck Drummond Island Rocks - you can tag me. hover over the drummondislandrocks text for the tag. I took over the account my kid started when he was 12 yrs old so it still has the name he entered. Chuck
Post by jamesp on Mar 2, 2017 14:28:17 GMT -5
Now I'm scared! You need AO polish which is typically 14,000 Tough finding AO after 1000. Think James found an AO 5,000 awhile back, don't recall where. jamesp ? Going from 1000 to polish should do ya fine. ETA: get AP polish anywhere, Rock Shed is where I get small grit/polish amounts. Kingsley North for bulk. Only used the 5000 a couple of times Bob, seemed redundant. Got as a sample from Lortone.
Post by Jugglerguy on Mar 2, 2017 15:06:48 GMT -5
I use a mix of small and medium ceramics from The Rock Shed. I bought some from Kingsley North once that I didn't like as much. I use at least 30% in each load.
I store my grit in gallon milk jugs for large quantities. For the stuff I'm currently using, I use Rubbermaid Take Along boxes.
Post by melhill1659 on Mar 2, 2017 22:00:07 GMT -5
Do you have ceramic media? I'm no Lot-O user, but I recall them folks use small ceramics as filler. Rock Shed has that too. Jugglerguy Drummond Island Rocks <-- can't tag Chuck Yep I have ceramics! Just looking for the best last step. You know the one that makes all those day to day rocks into Gems 😂
Post by Drummond Island Rocks on Mar 2, 2017 22:26:10 GMT -5
Not sure what you mean by last step. After final polish most folks are doing a quick burnish in the loto for a couple hours. I prefer and use borax but that is toxic to plants so if you are worried about that you can use a soap like dreft or even ivory soap flakes.
I use two tablespoons of borax and a little more water then I use in the rest of the steps. I put the rocks in wet add the borax then turn it on and squirt in enough additional water to get the consistency I like.
No trick for making day to day rocks into gems. Garbage in = semi shiny garbage out. Quality rough in = shiny gems out.
