alecogeorgia
Antithesis of tumbling - Friction retards progress
Member since January 2016
Post by alecogeorgia on Apr 12, 2017 23:41:41 GMT -5
Hi folks, Do you have any experience with jaw crushers to reduce size of the rocks to be tumbled? I have a challenge now to process many lbs of 2-3" stones into chips 1/2 and a bit smaller. It is crazy to buy a machine for the occasional use. I'd rather rent one. But where..?
richardh
Member since June 2016
Post by richardh on Apr 14, 2017 20:55:36 GMT -5
I don't know if this is useful but I had some success soaking some large cobbles for a few days in water then I cooked them in the BBQ pit for a while and ended up with some much more manageable material.
Post by spiceman on Apr 14, 2017 21:18:09 GMT -5
That's a good idea of water and a fire pit. You just need to be careful but you know that.
I was just thinking about that but maybe after the water soak freeze the rocks and let the ice do the job. It sure cracks the roads real good. Put them in Tupperware to keep the pieces of rocks in one place. Just a thought.
richardh
Post by richardh on Apr 14, 2017 23:21:54 GMT -5
That's a good idea of water and a fire pit. You just need to be careful but you know that. I was just thinking about that but maybe after the water soak freeze the rocks and let the ice do the job. It sure cracks the roads real good. Put them in Tupperware to keep the pieces of rocks in one place. Just a thought. Yes some of them explode in the fire pit. I keep the lid closed to avoid getting hit by fragments. I also have wrapped them in aluminum foil which so far has done a good job keeping all the pieces in one place. I also has the freezing idea but got yelled at for putting rocks in the freezer. I have been told that my rock activities will be limited to the garage and outside.
Post by spiceman on Apr 15, 2017 20:05:58 GMT -5
That's funny because I think you wife has been talking to mine.:)
My wife ask me to move them to the shed. No way
Wooferhound
Lortone QT66 and 3A
Member since December 2016
Post by Wooferhound on Apr 16, 2017 5:20:58 GMT -5
I've been breaking up quartz on the back corner of my patio cement slab But this is fairly hard on the cement and is starting to wear a depression in it. I remembered that I have a railroad track baseplate that I can use as an anvil and backup plate for the rocks being pounded. Won't get to try it out for a coupla weeks though because I have already busted up all the Rough that I have right now.
Post by parfive on May 29, 2017 1:03:37 GMT -5
