Luminin
Member since August 2017
Post by Luminin on Dec 16, 2017 15:30:43 GMT -5
Ordered 2 pounds of Cerium Oxide POLISH. We'll see in 2 weeks after it comes in and I get it rolling. Can't believe I'll have been running Pre-Polish for a month by then... I haven't given up on my Lapis yet, jamesp, maybe a month in AO Pre-polish is all it needed. π
Post by jamesp on Dec 16, 2017 15:39:12 GMT -5
Ordered 2 pounds of Cerium Oxide POLISH. We'll see in 2 weeks after it comes in and I get it rolling. Can't believe I'll have been running Pre-Polish for a month by then... I haven't given up on my Lapis yet, jamesp, maybe a month in AO Pre-polish is all it needed. π Send me a few. I'll run it with some other stuff as an experiment and return it. May be successful. Lapis on the bucket list. I may drop it if i can't do well w/it.
Post by Jugglerguy on Dec 16, 2017 15:51:19 GMT -5
Ordered 2 pounds of Cerium Oxide POLISH. We'll see in 2 weeks after it comes in and I get it rolling. Can't believe I'll have been running Pre-Polish for a month by then... I haven't given up on my Lapis yet, jamesp, maybe a month in AO Pre-polish is all it needed. π I always use aluminum oxide polish from the Rock Shed with great results. Cerium oxide is really expensive,
Luminin
Post by Luminin on Dec 16, 2017 15:52:43 GMT -5
Yes, it wasn't cheap, but I am running some softer stones and want to give them every chance at a good polish.
Post by rmf on Dec 16, 2017 16:26:20 GMT -5
you can reuse tumbler polish multiple times if you are really clean with your rocks. I have used it up to 10 times before I had to throw it out.
Just be sure to clean drum and rocks after las grind really well. Also it does not hurt if you can purchase a drum for polishing only.
Luminin
Post by Luminin on Dec 16, 2017 17:04:27 GMT -5
I give them all a good scrubbing between each change in grit. Each stage even has its own dedicated toothbrush for the job!
Post by aDave on Dec 17, 2017 0:01:13 GMT -5
Ordered 2 pounds of Cerium Oxide POLISH. We'll see in 2 weeks after it comes in and I get it rolling. Can't believe I'll have been running Pre-Polish for a month by then... I haven't given up on my Lapis yet, jamesp , maybe a month in AO Pre-polish is all it needed. π Cody, for my mixed batches, I use 14,000 (one micron) AO polish. It hasn't failed me yet. Everything that I've posted (and I have another batch yet to photo) was finished off with that. I'm speaking to using a rotary, so I think we're doing the same stuff...or at least using similar equipment. My last few batches were run in polish for 3 weeks. That's just me.
Luminin
Post by Luminin on Dec 17, 2017 8:24:34 GMT -5
aDave where do you buy it from? The Rock Shed?
Post by aDave on Dec 20, 2017 20:21:21 GMT -5
aDave where do you buy it from? The Rock Shed? Cody, sorry for the delay. I just haven't had a chance to get on lately. Rock Shed should be a good source. To be honest with you, I don't recall where I bought what I have on hand. Just remember that if someone lists polish as "1 micron AO," it is the same as 1:14,000. That's what I use, no matter how it's labeled. Hope that helps some. Dave
