Post by MsAli on Dec 30, 2017 19:14:43 GMT -5
Think I've burnt out the bit already😦 1st one I cant get the dremel to drill all the way thru. 2nd on I don't like the wire, so re doing it
Post by HankRocks on Dec 30, 2017 22:18:19 GMT -5
What size drill bit are you using?
Post by MsAli on Dec 30, 2017 22:22:47 GMT -5
I am ashamed to admit I don't know. It was giving to me to try.😕
Post by MsAli on Dec 30, 2017 22:39:47 GMT -5
The bit
Post by fernwood on Dec 31, 2017 7:58:27 GMT -5
I have used open end rivets in the past as well. Have some old stock copper and brass ones, which work well. They prevent the wire from wearing down the inside of the hole on softer stones. These were from Tandy leather in the 1980's or 90's.
Post by MsAli on Dec 31, 2017 9:43:10 GMT -5
I have used open end rivets in the past as well. Have some old stock copper and brass ones, which work well. They prevent the wire from wearing down the inside of the hole on softer stones. These were from Tandy leather in the 1980's or 90's. That's a good idea also.
Post by rockjunquie on Dec 31, 2017 11:00:04 GMT -5
I was reading a thread in the tute section on drilling holes. I can't remember which one, but he used wire drill bits with diamond coating on the ends. That's what I bought to use. That and a bur to start the hole and prevents the bit from skipping. eta- here it is forum.rocktumblinghobby.com/thread/35856/drill-pendant
Post by fernwood on Dec 31, 2017 11:35:22 GMT -5
I was reading a thread in the tute section on drilling holes. I can't remember which one, but he used wire drill bits with diamond coating on the ends. That's what I bought to use. That and a bur to start the hole and prevents the bit from skipping. eta- here it is forum.rocktumblinghobby.com/thread/35856/drill-pendantYes, I have several dremel bits I used for drilling. All had a small, diamond dust, ball on the end. The shank was straight, with no groves. Works great.
toolnut
Member since December 2017
Post by toolnut on Dec 31, 2017 11:40:59 GMT -5
Cool. Only suggestion is to seal the hole area. Looks unfinished now. That would add a lot. Yes, I think the wrapped bail is wire wrapping. Some might not agree. Can you drill the hole before the final polish? Then it would be a polished hole. JMHO What do I seal it with? I could try to drill one before, the final polish. I would think it would have to be done just before that step so stone has shape I want... Any JMHO are greatly appreciated Hoping this hobby can one day turn a small profit to just buy more rocks or maybe not have to work 2 jobs........so I'll take all the feedback I can get Try Clear fingernail polish works well for small areas you want a gloss in. Use it often to gloss eyes on carvings when the eye is burned into the wood and you want the black to shine like its wet.
Post by Tommy on Dec 31, 2017 12:59:30 GMT -5
Being the cheap thrifty person that I am I buy these bits from Amazon - $15 for 30 bits (50 cents each) can't beat it. I've never tracked it scientifically but depending on the hardness of the stone but I average between two and four holes per bit before they are toast. Sometimes when dealing with something very hard like Montana agate I might go through two bits to complete a single hole. smile.amazon.com/gp/product/B00AZMRZ4W/ref=oh_aui_detailpage_o02_s00
Post by MsAli on Dec 31, 2017 13:11:46 GMT -5
Being the cheap thrifty person that I am I buy these bits from Amazon - $15 for 30 bits (50 cents each) can't beat it. I've never tracked it scientifically but depending on the hardness of the stone but I average between two and four holes per bit before they are toast. Sometimes when dealing with something very hard like Montana agate I might go through two bits to complete a single hole. smile.amazon.com/gp/product/B00AZMRZ4W/ref=oh_aui_detailpage_o02_s00I got 3 and 1/2 holes out of it. Was wondering if this was normal.
Post by Tommy on Dec 31, 2017 13:22:53 GMT -5
I got 3 and 1/2 holes out of it. Was wondering if this was normal. I'm ecstatic when I get 3 or more holes out of a bit. These bits are just coated with a thin layer of diamonds. Once that layer gets compromised the bit is garbage. They make sintered bits which means that the diamonds are actually embedded in the metal - so the bit can experience wear and still cut as fresh levels of diamonds are exposed. I don't cut enough to justify using sintered - I've seen them upwards of $25 per bit on places like jadecarver.com - I have not found a 1mm sintered bit though or I'd probably buy it. jadecarver.com/product-category/burrs/sintered-burrs/
Post by Jugglerguy on Dec 31, 2017 13:29:21 GMT -5
I use the cheap 1mm diamond bits from Kingsley North. I buy 100 at a time to get the price down to $.75 each. I drill almost all pudding stone from Michigan. I get between zero and about a dozen holes per bit. When I tired to drill Lake Superior agates with the same bits, I used about two bits per hole. I might have to try the bits you use, Tommy.
Post by vegasjames on Dec 31, 2017 13:38:12 GMT -5
Being the cheap thrifty person that I am I buy these bits from Amazon - $15 for 30 bits (50 cents each) can't beat it. I've never tracked it scientifically but depending on the hardness of the stone but I average between two and four holes per bit before they are toast. Sometimes when dealing with something very hard like Montana agate I might go through two bits to complete a single hole. smile.amazon.com/gp/product/B00AZMRZ4W/ref=oh_aui_detailpage_o02_s00I got 3 and 1/2 holes out of it. Was wondering if this was normal. Putting the stone on a piece of wood in a shallow container and covering with water helps by keeping the bits from overheating. I also like using glass (carbide) bits for drilling holes for knife pins. Not sure if they come small enough for the small holes you will want.
Post by MsAli on Dec 31, 2017 13:40:10 GMT -5
I got 3 and 1/2 holes out of it. Was wondering if this was normal. I'm ecstatic when I get 3 or more holes out of a bit. These bits are just coated with a thin layer of diamonds. Once that layer gets compromised the bit is garbage. They make sintered bits which means that the diamonds are actually embedded in the metal - so the bit can experience wear and still cut as fresh levels of diamonds are exposed. I don't cut enough to justify using sintered - I've seen them upwards of $25 per bit on places like jadecarver.com - I have not found a 1mm sintered bit though or I'd probably buy it. jadecarver.com/product-category/burrs/sintered-burrs/ Might be worth investing in 1 rather than a bunch of them that add up tongue same price anyways
Post by fernwood on Dec 31, 2017 13:55:04 GMT -5
The ones I purchased from Menard's, a Midwest Wisconsin thing, were about $.75 each, when purchased in 3 packs. Three sizes of diamond balls on drills. Have had them for 5 years, with minimal wear. Drilled and shaped about 100 stones with them. Also, did some stone engraving. Still going strong. Unfortunately, I do not know if they are available on line, as I purchased them on clearance, in store.
Post by MsAli on Dec 31, 2017 14:15:48 GMT -5
The ones I purchased from Menard's, a Midwest Wisconsin thing, were about $.75 each, when purchased in 3 packs. Three sizes of diamond balls on drills. Have had them for 5 years, with minimal wear. Drilled and shaped about 100 stones with them. Also, did some stone engraving. Still going strong. Unfortunately, I do not know if they are available on line, as I purchased them on clearance, in store. I will have to send my brother over there and see if he can get me some or Fleet Farm. All we have here is Lowe's, HD, and OSH. All 3 didn' have much of a selection
Post by fernwood on Dec 31, 2017 14:35:12 GMT -5
The ones I purchased from Menard's, a Midwest Wisconsin thing, were about $.75 each, when purchased in 3 packs. Three sizes of diamond balls on drills. Have had them for 5 years, with minimal wear. Drilled and shaped about 100 stones with them. Also, did some stone engraving. Still going strong. Unfortunately, I do not know if they are available on line, as I purchased them on clearance, in store. I will have to send my brother over there and see if he can get me some or Fleet Farm. All we have here is Lowe's, HD, and OSH. All 3 didn' have much of a selection I have Lowe's and HD here. too. Missing Menard's, but I never agreed with the owners (John Menard) philosophy on store, environment, or racing cars, lol. The racing is a long story. Was a director at a facility who was a supplier of his for many years. Lowe's and HD, does not have the Dremel drill selection. Unfamiliar with the other. Amazon can be your friend for this, if you do the research and know what you want.
Wooferhound
Lortone QT66 and 3A
Member since December 2016
Post by Wooferhound on Dec 31, 2017 16:14:18 GMT -5
Post by MsAli on Dec 31, 2017 17:39:48 GMT -5
I will have to send my brother over there and see if he can get me some or Fleet Farm. All we have here is Lowe's, HD, and OSH. All 3 didn' have much of a selection I have Lowe's and HD here. too. Missing Menard's, but I never agreed with the owners (John Menard) philosophy on store, environment, or racing cars, lol. The racing is a long story. Was a director at a facility who was a supplier of his for many years. Lowe's and HD, does not have the Dremel drill selection. Unfamiliar with the other. Amazon can be your friend for this, if you do the research and know what you want. My Dad doesn't like Menards for pretty much the same reason. Fleet Farm is the one I miss. OSH, is a California hardware store that was bought out by Sears and now I think Kmart owns them. Great customer service and I can usually find what I need. Ex works there so now I never go. I won't even talk about how crappy the service is at HD and Lowe's. So online shopping it is.
