JR8675309
Member since August 2019
Post by JR8675309 on Jan 14, 2020 16:35:46 GMT -5
They have a very slender “kerf” so the blade bends easily. I am happy with how it cuts. Especially for $3 per blade. Leaves a very smooth edge if you don’t rush the cut. Thanks Knave! I really appreciate your taking the time to answer my questions. I got this whole set up in August but took me a while to get the oil delivery working well enough to take care of the blade. I’ve gotten tons of use out of the cabber, just want to shift use from mostly thunder eggs to some jewelry.
EricD
High in the Mountains
Member since November 2019
Post by EricD on Jan 14, 2020 17:02:43 GMT -5
The blade doesn’t get bent. It just moves a little with pressure. I don’t know how to say it. It easily deflects with horizontal pressure (you can push it to the side, but when pressure is released it returns to center)
Post by knave on Jan 14, 2020 17:07:10 GMT -5
The blade doesn’t get bent. It just moves a little with pressure. I don’t know how to say it. It easily deflects with horizontal pressure (you can push it to the side, but when pressure is released it returns to center) exactly!
JR8675309
Post by JR8675309 on Jan 14, 2020 20:33:58 GMT -5
I’m going to pick up the KN blade to have as backup; maybe a couple at that price. Now I just need to decide on the brand of wheel. Thanks
Post by knave on Jan 14, 2020 20:39:30 GMT -5
Single 6” blade is $5. Buy 3 it drops to 3.50
JR8675309
Post by JR8675309 on Jan 14, 2020 20:54:44 GMT -5
Single 6” blade is $5. Buy 3 it drops to 3.50 Dirt cheap. 8” is $8 and you can’t beat that.
gemfeller
Member since June 2011
Post by gemfeller on Jan 14, 2020 20:57:09 GMT -5
If I may chime in, I’m interested in the difference between a $200 -$250 sintered diamond wheel and the $80 - $100 Kingsley North wheels? If I may impose.... Maybe this was answered above - I skimmed the thread quickly. Sintered hard wheels have much thicker diamond coatings than the cheaper wheels, about 1/8-inch. And the diamond is heat-sintered into the metal, not just plated. That's what accounts for the difference in price. Sintered wheels last many times longer that simple plated wheels and IMO they're definitely worth the investment. They will last for years even with fairly heavy use. I do a lot of cabbing and I've been running heavy steel-core 60 and 220 grit sintered wheels on my Genie for over 2 years and they cut like new. No problems with the Genie's bearings either so far. I know a cutter who does far more heavy-duty cutting on a Genie with sintered wheels than I do and he's never had a bearing problem.
Post by knave on Jan 14, 2020 21:14:48 GMT -5
If I may chime in, I’m interested in the difference between a $200 -$250 sintered diamond wheel and the $80 - $100 Kingsley North wheels? If I may impose.... Maybe this was answered above - I skimmed the thread quickly. Sintered hard wheels have much thicker diamond coatings than the cheaper wheels, about 1/8-inch. And the diamond is heat-sintered into the metal, not just plated. That's what accounts for the difference in price. Sintered wheels last many times longer that simple plated wheels and IMO they're definitely worth the investment. They will last for years even with fairly heavy use. I do a lot of cabbing and I've been running heavy steel-core 60 and 220 grit sintered wheels on my Genie for over 2 years and they cut like new. No problems with the Genie's bearings either so far. I know a cutter who does far more heavy-duty cutting on a Genie with sintered wheels than I do and he's never had a bearing problem. Thank you! No, it wasn’t answered directly in this way, I appreciate it.
dbrealityrocks
Post by dbrealityrocks on Jan 15, 2020 4:25:04 GMT -5
Just my 2 cents worth, I have been using a sintered 80 grit wheel on a Genie heavily for 6 years and it doesn't seem to be even half way through the grit yet. I highly recommend spending the extra $ if you want a wheel that would last for years even with heavy use.
JR8675309
Post by JR8675309 on Jan 21, 2020 20:43:36 GMT -5
With talk of wheels and some thought given to belts in this thread: I’m curious if I should switch to diamond belts. My SiC ones seem to have worn out quickly this time. New at this, I’ve only ever bought two “sets” of SiC, I.e. 2X 100-1000 grit. What are the pros and cons of diamond belts? Also which grits do y’all tend to have? Lastly, who has the best prices? Are the Chinese ones on eBay legit or should I stick to KN OR TRS? What about Johnson Bros? Theirs are 34.95. Anyone else going broke just thinking about it? Lol. I purchased a cabbing machine and saw just this Aug (color me hooked). the cabber has an expanding wheel, diamond wheel and on the end I switch out spin heads. Thanks in advance and let’s hear it!
Post by Starguy on Jan 22, 2020 13:36:55 GMT -5
JR8675309Did your friend grind his rock on a dry wheel? That is the surest way to ruin a diamond wheel in a hurry. Those things last a very long time when water cooled.
JR8675309
Post by JR8675309 on Jan 25, 2020 18:50:56 GMT -5
Single 6” blade is $5. Buy 3 it drops to 3.50 knave bought the blade, now just waiting for the delivery. 😁
Post by knave on Jan 25, 2020 19:27:02 GMT -5
I can’t complain about mine so far.... still on the first wheel, been cutting quite abit.
Post by knave on Feb 5, 2020 0:39:21 GMT -5
I will not be using the cheapo blades in the future. They don’t hold up to the harder or bigger rocks. I can’t really recommend them.
JR8675309
Post by JR8675309 on Feb 5, 2020 19:38:37 GMT -5
Post by knave on Feb 5, 2020 19:49:05 GMT -5
Mk303 arrived today
Post by rockjunquie on Feb 5, 2020 19:53:54 GMT -5
Just dropping this in there..... the word everyone was looking for was "flex". The blade flexes.
Post by knave on Feb 5, 2020 20:26:13 GMT -5
And Tela flexes her vocabulary muscle! Lol
