Post by rockjunquie on Mar 24, 2021 12:14:57 GMT -5
I think it looks great. No girdle doesn't mean it has to be high domed. The plume is gorgeous. I don't think it would look right high domed.
Post by MsAli on Mar 24, 2021 13:24:02 GMT -5
I like it and think it does fit the criteria even if it's not a high dome.
Post by stephan on Mar 24, 2021 17:54:26 GMT -5
OK here is my entry - Carey Plume agate. I'm undecided if my entry really fits the parameters of the theme - I'm leaning towards not. I put a lot of time into it but in my opinion the result is sloppy and I'm not real happy with it. I thought I could get away with my usual style but taken on down to the bottom with no girdle, and about half way through it sunk in why this style lends itself to a higher dome. With the high dome the bottom edge comes closer to maybe an 80 degree angle where my thin cab has about a 20 degree angle and became quite sharp and inconsistent. When I tried to give it a backside bevel to prevent chipping it the result was it looks like a girdle unless you look real close at the angle. Before I decide what to do with this puppy I will probably clean up my wavy edges with the addition of a girdle. Lessons learned for sure thanks hummingbirdstones2 for the push. Mission accomplished on getting us out of our comfort zones Beautiful
Post by stefan on Mar 24, 2021 18:27:28 GMT -5
Good news is I have a nice Amethyst crystal all dopped up and ready to go! Bad news is my old Lortone Grinder is taken apart await someone to purchase it, and my new CabKing has not arrived yet! It shipped today so it should be here either Friday or Monday (lets hope for Friday) so I may be entering at the very last minute.
Post by hummingbirdstones on Mar 24, 2021 23:06:48 GMT -5
Tommy - I think you've met the criteria.
Post by orrum on Mar 25, 2021 10:54:23 GMT -5
Tommy that cab is over the top awesomeness!!!
Post by Tommy on Mar 25, 2021 11:00:03 GMT -5
Tommy that cab is over the top awesomeness!!! Thanks Bill! YOU are over the top with awesomeness
USMC15
I feel like I just came out of the tumbler ...
Member since March 2021
Post by USMC15 on Mar 25, 2021 11:59:20 GMT -5
Basically all of you are making a contact lens from a translucent rock. Interesting.
Post by stefan on Mar 27, 2021 7:45:51 GMT -5
betojdesigns
Member since September 2020
Post by betojdesigns on Mar 27, 2021 13:20:37 GMT -5
I have something to add. I had worked on this earlier, and was hoping I could have some time to make another cab, perhaps more interesting, but have run out of time. So, I used an end cut off of some rhyolite (correct me if that is not rhyolite). I chose a very small piece in case I messed it up. But, this one came out ok. I had another one that I created out of ruby zoisite that I got from Drocknut, but I chipped the bottom of it when I was removing it from the dop stick . I kept thinking I was working on a gum drop. Without the girdle it seemed a bit weird for me. Slab section Preform Finished cab Profile
Post by MsAli on Mar 27, 2021 18:22:18 GMT -5
Another two great additions!
Still some time to get some more entries
nik
Member since May 2019
Post by nik on Mar 28, 2021 22:36:13 GMT -5
Post by agatewhisperer on Mar 29, 2021 7:46:47 GMT -5
Great cabs everyone!!
Jahic
Post by Jahic on Mar 29, 2021 11:23:00 GMT -5
I’ll see if I can get mine done today/tomorrow. Great entries so far.
Post by MsAli on Mar 29, 2021 14:16:14 GMT -5
Post by hummingbirdstones on Mar 29, 2021 21:28:27 GMT -5
Here's mine. It's been done for a couple of weeks, but the weather was uncooperative all last week and I was having a real problem taking pictures without the color blowing out on me when we finally got some sun. You can see the blow-out a bit in the rough photo. Someday I will figure out how to actually use my camera. This is a crystal Aussie opal from the Lambina field.
The rough:
Cab:
Side View:
Straight-On End Shot:
And just for fun, here's the crystal test for opal:
Post by knave on Mar 29, 2021 21:30:13 GMT -5
Blow me over with an Opal I’ve never seen anything like it.
Post by hummingbirdstones on Mar 29, 2021 21:49:44 GMT -5
Thanks, Evan!
Post by rockjunquie on Mar 29, 2021 22:05:06 GMT -5
Beautiful opal!!!!
Post by hummingbirdstones on Mar 29, 2021 22:19:24 GMT -5
Thanks Tela! It has some green and turquoise in there that I couldn't get a picture of. The colors are metallic and a photographer I am not!
