Post by Starguy on Dec 7, 2023 3:06:12 GMT -5
That’s a really cool piece. It’s more agatized than most wood. Do you know the source? Pet wood can be so different from place to place. We went to Petrified Forest N.P. not too long ago. There are beautiful colors in the wood there but I didn’t see anything agatized like your piece. It was more like jasper. Thanks for showing.
Post by pebblesky on Dec 7, 2023 12:53:45 GMT -5
That’s a really cool piece. It’s more agatized than most wood. Do you know the source? Pet wood can be so different from place to place. We went to Petrified Forest N.P. not too long ago. There are beautiful colors in the wood there but I didn’t see anything agatized like your piece. It was more like jasper. Thanks for showing. I actually don't know. They are petrified wood scraps, and each piece has different patterns/colors. The other pieces look quite common. Some of them look like my earlier tumbled petrified wood from Tony's box:
hplcman
Member since August 2022
Post by hplcman on Dec 7, 2023 13:30:52 GMT -5
That’s a really cool piece. It’s more agatized than most wood. Do you know the source? Pet wood can be so different from place to place. We went to Petrified Forest N.P. not too long ago. There are beautiful colors in the wood there but I didn’t see anything agatized like your piece. It was more like jasper. Thanks for showing. I actually don't know. They are petrified wood scraps, and each piece has different patterns/colors. The other pieces look quite common. Some of them look like my earlier tumbled petrified wood from Tony's box: You know what? I think the background is almost as cool as those rocks!
Post by pebblesky on Dec 7, 2023 13:42:48 GMT -5
You know what? I think the background is almost as cool as those rocks! I think it is cool too! I took pictures of both sides: A forest. A land of a house with chimney.
Post by Starguy on Dec 7, 2023 14:17:59 GMT -5
That’s a really cool piece. It’s more agatized than most wood. Do you know the source? Pet wood can be so different from place to place. We went to Petrified Forest N.P. not too long ago. There are beautiful colors in the wood there but I didn’t see anything agatized like your piece. It was more like jasper. Thanks for showing. I actually don't know. They are petrified wood scraps, and each piece has different patterns/colors. The other pieces look quite common. Some of them look like my earlier tumbled petrified wood from Tony's box: The yellowish/reddish ones look more like what we saw in Arizona. I have a chunk somewhere that is pure, clear, colorless agate. The only way you can tell it’s wood is the “bark” on one side. Thanks for showing. Do you ever look at your rocks with a UV light?
hplcman
Post by hplcman on Dec 7, 2023 15:37:25 GMT -5
You know what? I think the background is almost as cool as those rocks! I think it is cool too! I took pictures of both sides: A forest. A land of a house with chimney. Wow, that is a stunning rock! Thanks for sharing a picture of it! You have a tumbler big enough for that thing?
Post by pebblesky on Dec 7, 2023 15:59:25 GMT -5
I actually don't know. They are petrified wood scraps, and each piece has different patterns/colors. The other pieces look quite common. Some of them look like my earlier tumbled petrified wood from Tony's box: The yellowish/reddish ones look more like what we saw in Arizona. I have a chunk somewhere that is pure, clear, colorless agate. The only way you can tell it’s wood is the “bark” on one side. Thanks for showing. Do you ever look at your rocks with a UV light? The only thing I remember about the bark side of that piece is it looks like the bark. Will take a closer look tonight. I haven't used the UV light. Sounds it would be a lot of fun...
Post by pebblesky on Dec 7, 2023 16:01:54 GMT -5
I think it is cool too! I took pictures of both sides: A forest. A land of a house with chimney. Wow, that is a stunning rock! Thanks for sharing a picture of it! You have a tumbler big enough for that thing? No I don't It came as a tumbled rock and I really wanted to see if I can improve the polish, at least on the green area, but it will be in the far future once I get some equipment, like a Dremel?
Post by pebblesky on Dec 25, 2023 20:38:23 GMT -5
Some of my tumbled Gobi desert agates. Some pieces have candy hearts in them encapsulated in the translucent crusts, but I need the sunlight to capture their beauty. The details on the surfaces are easier to capture in a light box. Zooming in: Zooming in again:
adam5
Member since August 2023
Post by adam5 on Dec 26, 2023 4:11:35 GMT -5
Very interesting surface!
Post by Starguy on Dec 26, 2023 12:39:15 GMT -5
pebblesky. That last agate photo is amazing. What a unique stone.
Post by jasoninsd on Dec 26, 2023 22:21:54 GMT -5
pebblesky . That last agate photo is amazing. What a unique stone. Yeah...that macro is stunning pebblesky!!
choochoorocks
Rock hounding
Member since April 2020
Post by choochoorocks on Jan 14, 2024 20:59:24 GMT -5
Wow, they are like a bowl of candy. Love that last stone too.
Do you use a special setup for macro shots?
Post by pebblesky on Jan 15, 2024 0:23:50 GMT -5
Wow, they are like a bowl of candy. Love that last stone too. Do you use a special setup for macro shots? I use a macro photography lens mounted on my iPhone and take photos in a small light box. Quite cheap and does its job most of time.
Post by pebblesky on Jan 18, 2024 20:15:13 GMT -5
Mounted my recently received mini UV bowl on my Raytech TV5, and the movement of rocks in the bowl was instantly improved. The noise level seems to be improved as well, although the db meter on my phone doesn't tell too much of a difference, which is a surprise. The smoothness of the tumbles after a run of 120/220 is satisfactory, although it is not a quantifiable measurement.
Last year I purchased a second Raytech bowl for polish only, so that I can save some time on excessively cleaning up work. Now it seems to be a waste. I don't think it is something my local facebook marketplace would be interested in...
adam5
Post by adam5 on Jan 18, 2024 20:28:24 GMT -5
I am glad you like the mini UV bowl As for the RayTech bowl, I have 3 that have been mostly unused since I received my mini UV bowl.
Post by pebblesky on Jan 18, 2024 21:28:10 GMT -5
I am glad you like the mini UV bowl As for the RayTech bowl, I have 3 that have been mostly unused since I received my mini UV bowl. Thanks! Your excellent tumbles really made me pull the trigger. Knowing that you have 3 RayTech bowls also made me feel much better!
dillonf
Hounding and tumbling
Member since February 2022
Post by dillonf on Jan 19, 2024 20:57:00 GMT -5
Those are some beautifully polished rocks!
Post by pebblesky on Jan 22, 2024 2:06:29 GMT -5
Got some new types of rocks to tumble from delivered packages today. Already threw some into my Rebel 17 before taking the pictures, but here are some saved for the next batch: Some are more grainy than the others, and they might end up having a subpar polish just like the picture "jasper" from rockshed. This one is among the most fine grained in the batch and might have some decent polish in the end. We will see. These roughs were from Hami, Xinjiang, China and have relatively smooth surfaces. I don't know if they have an official English name. Some high-quality (fine grained and beautiful patterns) roughs reminded me of Biggs Jasper with arguably more colors, but they are also very expensive. Here is a collage of the pictures I saved from the sellers' albums. Each rough has been asked for hundreds or even a thousand dollars, which is a bit crazy, so I collected the pictures instead of the rocks
Post by pebblesky on Jan 27, 2024 19:55:17 GMT -5
Finally finished a batch with the new UV mini bowl. It is a lot of work to sort the rocks and take pictures, so I will proceed slowly. The only Morgan Hill Poppy Jasper that I have tumbled, and I absolutely love it: Maybe I will wire wrap it once I learn how.
