Dryhead Agate, K2 Blue, Unknown, Teepee Canyon Cabochons
Nov 1, 2022 14:42:42 GMT -5
hummingbirdstones and liveoak like this
Post by jasoninsd on Nov 1, 2022 14:42:42 GMT -5
I use Nova wheels...which are very worn in at this point...280 soft through 3000 soft. After the wheels, I use 14K diamond paste on a canvas pad which is on my slant cabber. Then I have a Cerium Oxide pad on the end of the arbor which is my final step IF I use it.
And to be honest...not one of these cabs was put on the Cerium pad. The 14K diamond paste was the final step.
The only thing I think I do that most people don't...is I inspect the cab after every wheel. I have on reading glasses, a 5X Optivisor, and with those on, I look through my 3X magnifying light. So, basically it's the same as looking at the cab through a loupe after every stage. I can see the "level" of scratches that remain after each stage. It's not a liquid surface...so no matter what, there ARE scratches after each stage. I make sure each wheel has worked out the scratches put in by the previous wheel before moving it on to the next wheel. I do that inspection between each wheel...and then again after the 14K stage...and the Cerium if I used it.
Thank you Jason.
Sounds like it's all in the magnification !
Good tip & one I will try harder to implement.
Patty
Oh...they're not "always" shiny! LOL
from now on I’m following the South Dakota sage… all hail the king of shine!
I've seen your cabs...I don't think my polish and your polish are any different. Which means your polish is going to get crazy good if you start inspecting between each step!
South Dakota Sage! I kinda like that! LOL
Although...someone will abbreviate it to S.D.S. and someone else will think it stands for Safety Data Sheet...which definitely shouldn't be referred to me in any way! LOL
