Shelbeeray
Member since January 2006
Post by Shelbeeray on Oct 10, 2007 12:45:12 GMT -5
HEYYYYYYYYYYY - what happened to the pictures?
Post by Jack ( Yorkshire) on Oct 13, 2007 0:39:46 GMT -5
Hi Shellbelray.
I think the chap moved on and took his pictures with him !!
Im sure others will add their comment also
jack Yorkshire UK
AGATEGRRRL
AGATEGRRRL
Member since October 2007
Post by AGATEGRRRL on Oct 25, 2007 20:43:05 GMT -5
Hi Ron, I'd like to see what you're talking about, but I don't see any of the images in your posts. Where the pictures should be just has [image], but no picture. Am I the only one having this problem? Patti
Post by LCARS on Oct 27, 2007 15:04:02 GMT -5
Hey Dusty, Compound rubbing alcohol (ethanol) and a toothbrush will get Sharpie marks off fairly easilly. Apply a drop of alcohol on the offending mark/stain, allow 5-10 seconds for it to soak in and it should gently scrub out of the pores almost completely in a few seconds. Works for me anyway but i've never tried it on pet wood before...
schoodic1
Member since December 2007
Post by schoodic1 on Dec 8, 2007 19:30:51 GMT -5
Hi One and All: I`m looking for info on some stones that I tumble and that they took a very very long time to polish up ,something in the months (5) . These stones are chocolet brown with white streaks running in all different directions . The white lines are norrow (maybe a the thousands width up to a 1/32 of and inches The brown like I said is like a candy bar brown. Can anyone show a little light on these as to what they might be? I thank You for Your Time. schoodic1@wildblue.net
Post by Jack ( Yorkshire) on Dec 9, 2007 3:25:52 GMT -5
Hi If you put a photo on in the Photo or better still the general section Someone will be able to help im sure
Any way welcome to RTH
Jack Yorkshire UK
Post by Jack ( Yorkshire) on Jan 1, 2008 3:18:01 GMT -5
Hi This gives you a lot of detail
I hope it is helpfull
Jack Yorkshire UK
Post by Jack ( Yorkshire) on May 12, 2008 3:22:38 GMT -5
Hi Racoon. Bumped this article up 4 U
Jack Yorkshire UK
Post by Titania on May 27, 2008 13:09:10 GMT -5
My hubby just got me one of the Dremel drill press rigs for drilling stones...I've got it put together and am hoping to get to use it this week sometime.
Post by Jack ( Yorkshire) on May 28, 2008 2:12:58 GMT -5
Hi Titania,
Hope all goes well with the dremel,
Incidentally I'm using a ordinary Bench drill to drill with and use the dremel for polishing
I find a slower speed is better for me I can "feel " the bite of the bit and get a lot more life out of the drills
Used under water I can get a hole drilled in 3 to 5 mins depending on the hardness and thickness of the rock
There is a lot of good advicefrom Ron earlier in this thread Page 3
Jack Yorkshire UK
Post by Jack ( Yorkshire) on Apr 22, 2009 2:24:37 GMT -5
Hi RT Drilling ------- Bumped up for you
Jack Yorkshire UK
drjo
Honduran Opal & DIY Nut
Post by drjo on Apr 22, 2009 11:23:01 GMT -5
no pix.
Post by Jack ( Yorkshire) on Apr 26, 2009 1:47:07 GMT -5
Hi Drjo,
Just checkReply # 40 on Page 3
Mitchigan Rocks put a few photos on in this reply
Jack Yorkshire UK
Post by Jack ( Yorkshire) on Sept 19, 2009 0:44:42 GMT -5
Hi James, I Bumped up for you
Jack Yorkshire uk
