kjohn0102
Member since April 2006
Post by kjohn0102 on Dec 1, 2007 19:18:21 GMT -5
Anything wrong with tumbling with steel shot and some borax? That's the way I clean and harden all of my wraps, and they look amazing. Karen (aka KJ)
rockmegently
Member since February 2009
Post by rockmegently on Feb 28, 2009 12:48:57 GMT -5
The fastest and easiest way to clean is to make a galvanic cell. Simply lay a piece of heavy duty aluminum foil on the bottom of a shallow cup or other small container. Nothing big- just enough to hold the piece you want to clean. Lay the silver piece on the aluminum foil making sure it comes in contact with it. Make a solution of warm water and baking soda. Pour into the container. Works fast so watch it. Check- when clean- rinse with water and dry. This method is fast and won't harm the stones. invisibleuser Wow, this worked great on a set of rhodocrosite wrapped earrings(with chain and beads) and pendant that have always been a challenge to carefully polish, took about a minute!
Post by mohs on Feb 28, 2009 18:05:49 GMT -5
Hey rockers silversmith people :help: I have 12” silver plated platter, with lots of fine engravings (Oneida Georgian Loroll) and its tarnished really bad. I’ve bought Simi Chrome Polishing paste and can tell it going to buff up nicely. My question is: would it be all right to do the galvanic cell bath first to remove the heavy tarnish? thanks Ed
Post by mohs on Apr 19, 2009 19:32:46 GMT -5
I put this platter in a tin roaster with heavy duty foil dowsed with boiling water basically a whole boxof baking soda I even scrubbed it with the foil it worked well now I'm doing polishing/buffing with the paste pretty happy with the result so far
buck570
Post by buck570 on Apr 19, 2009 19:47:27 GMT -5
i clean all my silver in the tumbler, stainless shot ,dawn dish washing detergent. works fine. the shot is chopped up stainless tig rod and small stainless nuts and bolts. tumble the shot with sc grit to soften all the edges, rinse well and save for jewelry,just a drop or two of detergent, works for wraps to,
cooknet
Post by cooknet on Jul 19, 2009 10:31:27 GMT -5
Hi all, I don't like to correct people, and come off like some arrogant jerk or anything, so please do not take my comment the wrong way! I just wanted to state that I totally disagree with the suggestion by Rick that it is ok to put OPALS in an ionic cleaner, or ultrasonic cleaner of any kind !! I have been working with opals for many decades, and I can tell you that I have personally seen the destruction to an opal that an ionic or ultrasonic cleaner can do to a stone. Unless this device is some "special" device specifically built for polishing opals, I would definitely suggest that you NEVER subject an opal to this kind of cleaning, opals contain water, and if you expose them to a frequency such as the usual 25Khz frequency that these cleaners usually use, you can actually "boil" the water inside the opal, resulting in the stone either splitting apart, or actually exploding! Again, I don't mean to imply that I am any more of an expert at anything than anyone else, but I have seen for myself people's tears as their precious stone they have owned for years desinigrates before their very eyes, and believe me, you don't want to be responsible for destroying someone's prized opal, especially at the price they are now due to the current hike in opal costs, as so many miners have now abandoned the opal mines to mine gold in Australia instead! Hope this helps, I just would rather err on the side of caution myself! Chris
Post by susand24224 on May 31, 2010 15:02:38 GMT -5
At the risk of hijacking the thread (somebody please tell me if they think this should be a new thread), will the aluminum foil/baking soda formula work for gold filled wire? If not, any other suggestions?
Thanks,
Susan
Post by sandsman1 on Aug 3, 2010 13:44:59 GMT -5
i dont know if it will mess with gold but you can find out easy enough take some scrap wire from your wraps and try it on that and see if it hurts it in any way -- do it a few times to see if many cleanings hurt the surface of the wire and then just try and bend a few pieces see it it gets more brittle or not -- i never tried gold but i do know with silver after a couple times it seems like the tarnish comes back faster maybe its me doing something wrong but after i dry it with a rag i wipe it down with a jewlers cloth that has polish in it
prairiedog41
Member since October 2009
Post by prairiedog41 on Oct 31, 2010 17:44:23 GMT -5
We just soak it in Palmolive dish soap for about 1 minute or so, rinse it off and pat it dry. Seems to work great for any of our silver items.
-=Will=-
Post by Pat on Dec 28, 2012 19:44:19 GMT -5
I've cleaned a lot of sterling silver in my little tumbler using stainless steel shot and a drop or two of Dawn Dish Soap. Works very well.
Now I want to clean tarnished silver that has been set with faceted stones: lab ruby, cz, topaz and others. The pieces were not tarnished when I set them.
Has anybody tried this and has it been successful?
I've used Goddard's Dip and Tarn X, but it turns many of the pieces gray. What's going on there?
Rio's Sunshine Cloth works well, but cannot get in the little nooks and crannies.
Thanks.
metalsmith
Post by metalsmith on Mar 19, 2016 14:52:13 GMT -5
Fine silver is white, so it's likely that the dips are stripping the copper out of the Sterling alloy just as pickle does. Burnishing should bring the metal back to a literal fine silver shine.
Post by radio on Mar 19, 2016 15:18:14 GMT -5
Post by mohs on Mar 19, 2016 21:33:15 GMT -5
silver anniversary post its a great thread!
