Post by Jack ( Yorkshire) on Feb 4, 2009 3:04:39 GMT -5
Hi Mosseyrockhound, Get round to making one at the earliest oportunity,
as I have used one for a few years (see above) they are a great help and I can highly recomend them
Jack Yorkshire UK
PS Works a lot better after a spell of cutting and oil is warm, John
DeanW
Member since December 2007
Post by DeanW on Feb 9, 2009 12:46:49 GMT -5
Dayum! I'm gonna build one of these for my saws; thanks all for the ideas and pics.
mossyrockhound
Member since January 2011
Post by mossyrockhound on Feb 15, 2009 21:42:34 GMT -5
Well, I put together my slab saw sludge sucker the other day and thought I would try it out on my little 16" HP saw first. Man! It worked so great that I thought I could suck up anything with it! Bad assumption. I looked at the catch tray that was full of chips and caked-up oil and I proceeded to vacuum those up. Mistake. Those chips with the caked oil did a great job of jamming up the (clear) suction tubing. I made my suction hose about 7.5 feet long because I have some bigger saws that I plan on using this gizmo on. After I found an eight-foot length of rebar to use as a ramrod, I finally knocked out the blockage. Anyway, after I got going again and finished up getting the sludge out of that saw, all I can say is that I'M IMPRESSED! Also, I found out that Shop Vac makes a 1" adapter (which I just happened to have on hand) that fits perfectly into the flexible pour spout of the 5-gallon bucket lid, where you attach your vacuum hose. I can see where I am going to be using this sludge sucker for a long time! Thanks again for posting this!
Mudshark
Diplomacy is the art of saying 'Nice doggie' until you can find a rock. Will Rogers
Member since December 2008
Post by Mudshark on Feb 16, 2009 9:53:03 GMT -5
I made mine last week and finally got to try it out yesterday,Wow :DI have a couple of small squeegees that I used to get all the sludge to the bottom of the saw and then used the sucker.I was amazed at how quickly the saw became clean.I used 1 1/4" sump pump hose.It sucked up everything big enough to fit in the hose.Thanks again for posting this. Mike
Post by Hard Rock Cafe on May 8, 2009 17:05:43 GMT -5
amyk
I'm a slabber, I'm a cabber, I'm a midnight wrapper.
Member since January 2010
Post by amyk on Jan 30, 2010 11:50:36 GMT -5
Wow!!! I have GOT to make me one o those!
docharber
Member since October 2008
Post by docharber on Feb 26, 2010 1:28:25 GMT -5
For those of us that with less time to spend fabricating our own, similar devices are available from woodworking suppliers for chip collectors- I've seen lids made to fit galvanized garbage cans . All you would need is a sucker wand (crevice tool might do) and a few feet of hose. There may be something smaller available, too. It would be neat to have the muck dump right into a filter bag and let the clean oil drip into the bottom of the garbage can.
By the way, is ther any reason you couldn't build this thing with PVC pipe?
Matrk H.
drjo
Honduran Opal & DIY Nut
Post by drjo on Feb 26, 2010 5:33:07 GMT -5
Put a brick in the bottom of the bucket and a piece of egg crate (for suspended lighting) on top of it, then place the paper bag (fold the top a few times to stiffen it) under the input to the bucket to catch the muck.
Dr Joe
Post by quartz on Mar 6, 2010 20:34:26 GMT -5
slick idea, likely try one too, thanks. Any idea of mfg. of saw. We have one of same saw [16"], bought from original owner who bought it in Portland, OR. He didn't remember name of maker.
Post by catmandewe on Mar 6, 2010 23:44:40 GMT -5
HI Quartz, That is a Royal Rock saw made by Jenkins Lapidary out of Portland, OR. There are quite a few of these around, and they work pretty good. Lots of the guts were also sold as kit saws and can be found in older home made saws, alot of which used plywood boxes and other kinds of home made boxes.
Glad lots of people found this useful, the THANKS really goes to Harley(Agatemaggot) who came up with the original idea and just told me his idea over the phone.
Have a great day everyone! Tony
Post by quartz on Mar 9, 2010 22:50:51 GMT -5
Thanks catmandewe, nice to know the saw brand and where it was made.
zarguy
Member since December 2005
Post by zarguy on Jun 16, 2010 21:11:14 GMT -5
Has anyone made the slab saw sucker with 3/4" conduit for the wand? I can't find 1" conduit in town. I've got a 14" saw to slurp out.
Lynn
Post by catmandewe on Jun 16, 2010 22:23:02 GMT -5
I don't even use the wand anymore, it is just another part to plug up. I just have the 1 1/4" hose now with no wand, it just works better that way.
Tony
Post by Hard Rock Cafe on Jun 22, 2010 12:55:54 GMT -5
I just use the crevice tool that came with the hose.
zarguy
Post by zarguy on Oct 22, 2010 21:18:02 GMT -5
I built one & used it on a 14" HP saw that I bought used. It had a thick layer of muck on the bottom & even that got sucked right up. It's now a couple of months since I first used it & I've been cutting lots of Indian Blanket Jasper. Man, talk about mud! It looks like I've been cutting bricks. No I said "cutting"!
The mineral oil I've started using seems to get absorbed by the muck. I hope I can recover it.
Lynn
Post by Hard Rock Cafe on Oct 22, 2010 22:43:47 GMT -5
I know what you mean. I've got some really oily rock snot and I'm thinking I might have to press the oil out because it's not coming out on it's own.
Post by jakesrocks on Oct 22, 2010 23:02:15 GMT -5
Dump your rock snot in a bucket, fill the bucket 3/4 of the way with water and stir it real good with a stick. After a couple of days the mud will settle back to the bottom, and the oil will float on top. Just dip the oil out with an old cup.
zarguy
Post by zarguy on Oct 29, 2010 23:28:56 GMT -5
Great suggestion. I'll give it a try.
Lynn
Post by phil on Oct 14, 2012 15:08:00 GMT -5
If it helps, When Our oil gets that thick, I just add a gallon of clean oil, stir it up then drain it out. Works real well. last time we cleaned our saw, I remove the drain plug and replaced it with a 3/8th inch pipe nipple. Then I added a ball valve, some clear plastic tubing, and when it's time to clean the oil, I stir the sludge up real well, tile the saw ever so slightly, open the valve and drain the sludge directly into some ready to go grocery bag lined 5 gal buckets with a shelf 1/3 of the way up so the bottom of the bags can drain fast, and also so there is room for the clean oil to go. I use two buckets to do 5 gallons of sludge, and the whole thing takes me maybe 15 minutes! Could be adapted with larger barrels for sure! I did learn to filter more often, which afaic, is a good thing. No, I don't super clean the inside of the saw, just scoop out he left over rock bits and etc, and then fill it with the clean oil. I can't see cleaning it "Clean", I mean heck, why? The first rock I cut is going to dirty the saw anyway, so as long as there's not much left in there, it doesn't hurt anything. End result? Dirty job now a fast, relatively clean one. I can take some pics if anyone wants. I do like the vacuum idea tho for our other Lortone drop saw..... the way it is constructed I can't stir the sludge up to get it thru the drain... too much stuff in the way... but I should be able to shove a sucker tube most everywhere and get it clean enough! Phil
Post by Rockoonz on Oct 15, 2012 18:43:09 GMT -5
Thanks for the bump Phil. Now that I'm running between 5 saws I need to make my snot sucker. I usually keep a gallon of diesel on hand to thin out the oil a little and to wash the snot out of the carriage and slab tray. old used oil absorbs the smell pretty quickly.
Lee
Lee
