drjo
Honduran Opal & DIY Nut
Post by drjo on Dec 24, 2008 22:59:30 GMT -5
Drums are the only hold-up. I've got several ideas but have to test them first.
Trying to find universal parts / suppliers for US & UK.
Dr Joe
CUL-Ann
rock lover~
Member since September 2008
Post by CUL-Ann on Dec 24, 2008 23:46:15 GMT -5
I have 4 drums from 2 junk dual tumblers!!
docharber
Member since October 2008
Post by docharber on Dec 25, 2008 0:06:10 GMT -5
If I compare to my lortone 33B, obviously the model fgor the CE tumbler, i have to admit the electric cord, is heavier and the barrels better quality on the CE. The CE chassis has metal sleeve bearings, not cheap plastic like my Lortone, and the chassis is just as sturdy overall, with better motor colling and a heftier motor to boot- when it works. Teh Chinese mtor is pure crap. The end bearings ar set in flexibnle plastic, and when the belt is attached the tension warps the plastic and the motor grinds to a halt. It isn't salvageable. you can replace the motor fairly easily with a Lortone motor and you're off again. Buy replacement belts from Lortone or even off eBay- I cought some reound-cross-section belts and they're great.- I haven't needed to replace the belt a second time yet. When I first joined the Board I had this idea and was pretty proud of myself, until it was pointed out that just about everyone has worked this repair to make a serviceable tumbler. As for the friction one responder commented on- just adjust the little cleat on the end of the carriage and that will keep the barrels in position. Oild the bearings about every month or so with a little machine oil, or take it apart and clean it, then apply lithium grease. If they only had used a decent moor and belt, the CE tumbler would be a really good value. Still, you can buy one and rework it for less than the cost of a neew Lortione.
I have to take issue with the vendor who responded about you're desire to try to get a refund. The customer has a right to expect merchantability- the expectation an item is fit for the use intended. The CE tumblers, as sold, are not. Vendors selling these machines know they are crap, and are trying to make a quick buck on the gullible, who usually won't nbother to take the time or expense to return or contest the sale in any way. They are predators, and eBay should don more to control these people. If you complain to eBay, as I did once in a case of clear fraud, they charge you $25 PER ITEM to intervene. Paypal is a little better. i use my credit card through Paypal and they will give me full refund protectiomn free. So, don't fall for Paypal's buyer protection crap. They are worthless, eBay even more so. Lortone parts are available through several Lapidary supplies, like ACE and Alpha. Ithink they offer replacement 230 volt motors. Lots of luck, Merry Christmas, and Happy New Year!
Mark H.
Saskrock
Member since October 2007
Post by Saskrock on Dec 25, 2008 0:41:17 GMT -5
PVC barrels work pretty good drjo, they are just a little noisy.
1rockhound
Member since July 2008
Post by 1rockhound on Dec 25, 2008 0:45:18 GMT -5
Thats funny predators eh... So your saying that Harbor Freight is a predator since they are the main distributor for CE here in the USA. You get what you pay for and if you buy cheap stuff don't expect to get a product that lasts. I'm not a dealer of these crappy items just a person that knows that you don't get something for nothing.
Rogue Trader
"Don't cry because you are leaving, smile because you were there."
Member since December 2008
Post by Rogue Trader on Dec 25, 2008 0:57:17 GMT -5
I totally agree that you get what you pay for, but wouldn't you at least expect them to last longer than just a few weeks?
Post by Hard Rock Cafe on Dec 25, 2008 0:57:51 GMT -5
I agree the PVC barrels work pretty well, but I'd like larger capacity than I can get with 4" PVC.
Saskrock
Post by Saskrock on Dec 25, 2008 3:00:15 GMT -5
You can get PVC much larger than the 4" I used. It does get pricey though. I just used 4" because its about the same outside diameter as a CE tumbler barrel so it fits my tumbler.
drjo
Post by drjo on Dec 25, 2008 8:48:44 GMT -5
No 1rockhound, see my previous post with the quote from HF's ad, They're honest about it. Someone put up a link to the exact ebay CE sale item please so we can compare. .... CUL-Ann, 4 huh?, and they're just laying around! We're going to have to do something about that. ;D docharber, don't mistake thermoplastics or polymers for cheap plastic, of course if they use a type for not suited for the application it might as well be cheap plastic Dr Joe .
Post by Hard Rock Cafe on Dec 25, 2008 17:22:56 GMT -5
Saskrock: Agreed. The price of 8" pipe isn't so bad, but the fittings are a killer. The 2 companies that sell PVC barrels on eBay have priced them reasonably considering the cost of fittings.
drjo
Post by drjo on Dec 25, 2008 22:11:05 GMT -5
Ok, I dug back in over a weeks ebay sales and all CE type tumblers all say exactly the same line..."designed to run for days at a time". I did see that one ws sold for $1.33 and another for $3.61. Dr Joe .
Saskrock
Post by Saskrock on Dec 26, 2008 1:47:27 GMT -5
I would be the proud owner of 2 more CE's for that price. Can always use more barrels.
chassroc
Post by chassroc on Dec 26, 2008 9:08:38 GMT -5
Me thinks you missed the point. "designed to run" is not the same as "Guaranteed to run"... ;D ;D ;D csroc
drjo
Post by drjo on Dec 26, 2008 18:09:39 GMT -5
Of which they are neither ;D
docharber
Post by docharber on Dec 28, 2008 18:39:34 GMT -5
i'm using 1/2 inch ball bearings on aluminum shafts for my new tumbler. I goused flange bearings and set them into the end boards (MDF) using spade and Forstner bits of appropriate diameters to make them flush. you will have to tap the bearings on and maybe grind/sand the shaftys to accept them as the fit, on mine at least, was really tight and you have to be careful to tap the bearings on perpendicular to the shaft to have it run smooth. i cut small lengths of vinyl tubing with an ionterior diameter of 1/2 inch onto the shafts before mounting the bearings to give the roller surfaces a diameter of 3/4" i found the aluminum rods at Home Depot and the bearings at a large Ace Hardware. the aluminum is easier to cut than steel and won't rust. It's plenty strong enough, too. It cost only about $7 for a 3 foot rod. That's about the same as steel. About the bbearing alignment- you can tyell if they are not well aligned as there will be a little drag and noise . Be gentle with the installation as the races can qwarp. And thank you, CUL-Ann, for the photo. It inspired me to try something with PVC and Portone lids to solve the problem of how to make PVC barrels that will seal and not cost me a fortune for end pieces.
Mark H.
Saskrock
Post by Saskrock on Dec 29, 2008 2:02:27 GMT -5
I'm not sure what a Portone lid is, but I have tried a few things and plumbers plugs like this are the best I have found. Just be sure to put a piece of rubber over the inside plate so it doesn't wear. 4" ones cost me $8 at home depot.
ejs
Post by ejs on Dec 29, 2008 9:41:19 GMT -5
docharber says:I goused flange bearings and set them into the end boards (MDF) using spade and Forstner bits of appropriate diameters to make them flush. Well, that's great and all, but did you make sure to deflugle the cross-sectional goosebearings with your nontorquing Mitchell gagglebit? If you didn't, well, we all know what will happen then! (Okay, I'm man enough to admit that I have no idea what the heck he is talking about! That sentence makes my head spin.)
drjo
Post by drjo on Dec 29, 2008 10:56:25 GMT -5
Nope he used the chrome ones. All's good.
Post by MyNewHobby on Jan 17, 2009 12:39:13 GMT -5
Good morning!
I am glad that I saw this post.
Since I am so new to this, I was thinking about buying a Chicago tumbler. During research I found out about the Chicago tumbler. They are available through Harbor Freight. The 3-lb dual barrel (model 90979) is on sale for $49.99. I guess you get what you pay for applies here.
Guess I will not buy it and will save up in the next few weeks to get one of the higher end tumblers (dual barrel).
Thanks all for making your experiences available to those like me that do not know better.
ps ... can you tell I am in between tumbles? ;D
I am waiting for my goodies from MichaelJohn.
CUL-Ann
rock lover~
Post by CUL-Ann on Jan 17, 2009 19:53:52 GMT -5
For your tumbler go to www.mamasminerals.com/page/MM/PROD/TUMROT/EQT-BLTSMCode: EQT-BLTSM Price:$1.65 Replace your worn or damaged Lortone Rock Tumbler 1.5 or 3A Belt, or keep an extra one on hand for emergencies. This belt also works with any tumbler that uses a belt with a 9" circumference and 1/4" thickness. The Chicago tumbler belt will not last for even 1 tumble but replacing it with this lortone belt works and this place sells up to 4 belts per order for 0 shipping.
