Vibe
Mar 1, 2009 9:56:05 GMT -5
Post by beefjello on Mar 1, 2009 9:56:05 GMT -5
I picked this up on craigslist this past week. The guy had run one load through the stages and lost interest. Does anyone have one of these machines? Any advice for a vibe noob? My plan is to shape a bunch of cabs on the 100 and 200 wheels then finish 'em off with this. Thanks a bunch!
Vibe
Mar 1, 2009 10:33:13 GMT -5
Post by johnjsgems on Mar 1, 2009 10:33:13 GMT -5
Most important tip is damp not wet. If you see water splashing you will settle grit to near bottom of bowl, wearing grooves n bowl as rocks rotate above. Monitor every few hours until you get the hang of it and use approximately half the grit you would in a rotary. It looks like a TV5 so capacity is approximately 4 lbs.
Mudshark
Diplomacy is the art of saying 'Nice doggie' until you can find a rock. Will Rogers
Member since December 2008
Vibe
Mar 1, 2009 14:36:51 GMT -5
Post by Mudshark on Mar 1, 2009 14:36:51 GMT -5
Nice score,have fun with it.It should do a great job polishing your cabs. Mike
MikeS
Vibe
Mar 1, 2009 15:46:55 GMT -5
Post by MikeS on Mar 1, 2009 15:46:55 GMT -5
I use my vibe to polish and burnish most of my cabs, I've noticed I get much better results if I hand polish them first on the lap and then finish them in the vibe....
Vibe
Mar 1, 2009 19:10:04 GMT -5
Post by beefjello on Mar 1, 2009 19:10:04 GMT -5
Thanks a bunch guys! So if I shape on the 100 and 220 wheels, should I be able to start the vibe with a pre-polish? Maybe 500 grit?
MikeS
Vibe
Mar 1, 2009 19:31:13 GMT -5
Post by MikeS on Mar 1, 2009 19:31:13 GMT -5
That's what I usually do, depending on the material. I shape them on 100-220 wheels, sand any bad scratches out of them, then run them for 2-4 days in the vibe with 500 grit, recharging the grit daily. Then I hand polish them on the lap, then return them to the vibe for a 2-4 day polish with aluminium oxide, followed by a 12 hour burnish with ivory bar soap shavings. I've had good luck doing them this way, but some softer materials do not respond as well to this method, I have to do them entirely by hand.
Mike
Vibe
Mar 1, 2009 22:09:22 GMT -5
Post by beefjello on Mar 1, 2009 22:09:22 GMT -5
Great, thanks for the info Mike!
Vibe
Mar 1, 2009 23:01:07 GMT -5
Post by frane on Mar 1, 2009 23:01:07 GMT -5
That's the vibe I have. The only problem is the plastic bowl but if you are doing preforms without sharp edges, you should be fine. The stones should be damp when you put them in the bowl or use a spray bottle to dampen the stones, about 4 sprays should do it. Tighten the nut down to hold the bowl on, plug in and immediately add a pinch of ivory soap over the stones as they run. sprinkle in 1/2 teaspoon of 500 grit to cover the stones. It won't look like much but in about 2 hours it is a paste all over the stones. Unplug and put the lid on. At first, check every few hours until you know how your machine works for you. If you do not see a folding action going on and everything looks a little sluggish, add a few squirts of water to get it going again. if the bowl is not full enough, it will not fold as well as it should. You can add more grit after 12 hours but frankly, it is rarely needed. You should never add more than a second round of grit to the batch without washing the stones in between. It would get too sluggish. The grit breaks down really fast in a vibe, so after 24 hours your 500 grit has changed to about 1000. Have fun with it. I rarely do more than 2 days at each grit and the batch I just posted ran 3 days at 120-220, 1 day at 500, 1 day at 1000 and 1 day polish. (were preforms or ran in the rotary to get a shape before putting in the vibe to finish) Well, I think that is all I can say to help a little. Any questions, just ask. Fran
Vibe
Mar 2, 2009 2:55:10 GMT -5
Post by Jack ( Yorkshire) on Mar 2, 2009 2:55:10 GMT -5
Hi Beef, I use the Vibe(lot"O") to polish and get a great finish using Conrocks "Gloss finishing Guide" This is a set of letters helping me get started some one cleaned it up but it answers a lot of pre buying questions as well as a gloss polish see img.photobucket.com/albums/v357/john-edward/E-VibeApril2.jpgThis is some Obsidian (black and Maghony) Cabs I formed and rough grinded then put in the vibe at 220 Grit If you Email me I will be delighted to send you the guide its in 2 documents Email john@matco.me.uk I havent found the right way to attach documents to this site (RTH) Hers a few more Pre cuts ive done using this method img.photobucket.com/albums/v357/john-edward/VibeHGlossApril08Outside012.jpgIts a great way you can judge how sharp or beveled you want the edge of the precut Jack Yorkshire UK
DeanW
Member since December 2007
Vibe
Mar 2, 2009 12:18:48 GMT -5
Post by DeanW on Mar 2, 2009 12:18:48 GMT -5
Vibe
Mar 3, 2009 3:29:43 GMT -5
Post by Jack ( Yorkshire) on Mar 3, 2009 3:29:43 GMT -5
Hi Beef,
Deans the "clean up " Guy I mentioned above
Sorry Dean I forgot your name,
Jack Yorkshire UK
rockdewd
Member since October 2007
Vibe
Mar 3, 2009 12:59:36 GMT -5
Post by rockdewd on Mar 3, 2009 12:59:36 GMT -5
I rough my cabs out on a 60 grit diamond then smooth them on a 360 grit diamond flex wheel. I wish they made a heavier grit flex wheel. I then start them in the vibes at 120/220, then 600, then 1000, 2 days each stage, then polish with alumina oxide for a least a week.
YMMV
Rick
Vibe
Mar 3, 2009 20:59:52 GMT -5
Post by johnjsgems on Mar 3, 2009 20:59:52 GMT -5
Rick,
Flex wheels come in lots of grit sizes. 60, 80, 120, 220, 325, 400... Then there are the Nova and knock off "Soft Wheels" in 60, 140, 280, etc. Sorry, off subject.
rockdewd
Vibe
Mar 4, 2009 10:14:43 GMT -5
Post by rockdewd on Mar 4, 2009 10:14:43 GMT -5
John,
Thanks! I'll check them out. A 220 flex might be what I'm looking for...
ktg
Vibe
Mar 6, 2009 12:37:40 GMT -5
Post by ktg on Mar 6, 2009 12:37:40 GMT -5
I am really new to all of this. I am considering purchasing a rock tumbler but I am trying to decide whether to purchase a tumbler or a vibratory model. Can someone help me understand the difference & advantages of one versus the other? Thanks, Karen
Vibe
Mar 9, 2009 4:07:03 GMT -5
Post by Jack ( Yorkshire) on Mar 9, 2009 4:07:03 GMT -5
Hi Karen, In short you realy need both
Why To get a good shape you need a rotary that tumbles the rocks and gets the rough edges of quick a lot quicker than a vibe and more eficently and cheaper
The vibe ( My Lot"O") then takes over in speed and economy in stage 2 220Grit
It is never the less very very agressive in this stage and produces a lot of mud so you have to check every 2 to 5 hours and add a drop of water so they are glossy again
Note ( I must add that vibes run moist NOT like rotary tumblers that are filled to just under the top stones with water)
this stage takes 48 hours in the vibe 14 to 21 days in the rotary
stg 3 500grit 24 hours vibe week to 10 days in rotary
st 4 1000 grit 24 hours in vibe a week in rotary
Burnish vibe 5 to 10 hours rotary 24 to 48 hours
final polish vibe 2 days rotary 2 weeks rotary
(This is my system which is based on Conrocks Gloss guide for Vibes. see other threads on polishing for more information on this & a copy )
Hope this helps to answers your query Karen on the difference between Rotary and vibe rock polishing systems?
Jack Yorkshire UK
MikeS
Vibe
Mar 9, 2009 8:24:43 GMT -5
Post by MikeS on Mar 9, 2009 8:24:43 GMT -5
Jack brings up good points, it's definately best to have both types on hand (I have both also). However, if you are only going to get one type for right now, I'd start with a rotory, mainly for its superior ability to shape rocks in the coarse stage. Vibes don't do nearly as good a job at shaping, and you can't really run anything more coarse than 220 effectively in them. This is fine as long as the rocks you are tumbling are already very close to the shape you want, some shaping will take place with this grit in a vibe, but not much. Due to the length of time it takes to complete a batch in a rotory, you'll have some time to save money and get a vibe also...
DeanW
Vibe
Mar 9, 2009 8:45:23 GMT -5
Post by DeanW on Mar 9, 2009 8:45:23 GMT -5
To slightly restate the previous answers about tradeoffs: A vibe is quicker and does not round-off hardly at all; requires more checking; most (but not all) are more noisy. A rotary is more time consuming, rounds rocks, can be "ignored" for a longer period of time. Also, I believe (but not 100% certain) that and 10 pound vibe uses less grit than a 10-pound rotary, right? To add some confusion , sometimes 'not rounding' is a benefit. There are some rocks that you don't want to add any shaping to. For example, limb casts and cab-preforms. :2cents: Dean
Vibe
Mar 9, 2009 12:28:14 GMT -5
Post by Hard Rock Cafe on Mar 9, 2009 12:28:14 GMT -5
Yes, a vibe uses a lot less grit than a rotary.
My 15 lb. rotary requires 1 lb (16 oz) of grit. My 18 lb. vibe requires only 4 oz of grit. Tom (Connrock) and Jack use substantially less (teaspoons) in their Lot-O vibes.
docharber
Member since October 2008
Vibe
Mar 9, 2009 19:11:38 GMT -5
Post by docharber on Mar 9, 2009 19:11:38 GMT -5
My experience with this machine- if the stones are too wety the grit settles to the bottom. If too dry, they get a sticky, thick layer of clay on them that inhibits grinding. If the water content is just right, checked 12-24 hours into the cycle, the clay can be wiped with your finger to reveal the color if the stone. if too dry, it's very hard to do this. In the polish stage, you should be able to clearly see the details in the stones through the slurry which should be no thicker than milk. I keep a spray bottle handy to clean theinside of the lid and add water in controlled amounts- don't overdo it- until it's just right. I wet the stones before adding abrasive and add another 2 tablespoons of water to the whole thing with the abrasive, to start. One thing about this machine and any vibe- get a separate bowl for polishing. Also, I recommend you keep the threaded rod in the middle clean. It's a standard 1/4"-20 thread. I have found the rubber covered nuyts get jammed with grit quickly and a few sprays of water will loosen them. I have already replaced my ribber covered nuts with new ones in brass, like the cebnter rod which I have also replaces, and thick rubber washers from the plumbing section at HD. I use a wing nut on the outside of the lid.
Mark H.
