Post by mohs on Mar 3, 2009 15:38:05 GMT -5
Is there a way to tell before cracking it open?
A neighbor brought over a round rock. Thinks its geode.
I'm sure this as been discussed before. Us noobies! But I can post a pic later if...
Post by texaswoodie on Mar 3, 2009 16:52:28 GMT -5
Get a rock about the same size and weigh both. If it's a hollow geode, it'll be much lighter.
Curt
Post by mohs on Mar 3, 2009 22:57:25 GMT -5
Thanks Curt! The Eureka method, hey? I was out tapping that rock with a hammer, holding it up to my ear, listening. The neighbor asked what I was doing? Checking to see if it hard or hollow. I suppose that never works. Anyway here’s the rock or the geode in question. I think it just an everyday average round rock.
Post by texaswoodie on Mar 4, 2009 6:48:41 GMT -5
Looks like a Mexican geode. Phoenix should have a rock club. See if you can get someone to cut it for you.
Curt
Post by Hard Rock Cafe on Mar 4, 2009 9:43:45 GMT -5
Ed, I hope you're not really using a wood chisel on your rocks! LOL
Post by mohs on Mar 4, 2009 10:49:13 GMT -5
You guys really think it might be a geode?
Hey Chuck I have a WorkForce and will score the stone, and then... Yes, my plan was to use that wood chisel to crack that rock
What's wrong with that idea?
Post by Hard Rock Cafe on Mar 4, 2009 13:18:00 GMT -5
Well, I guess nothing is wrong with it if you never want to use the wood chisel on wood again. Wood chisels are made so that they can be sharpened to a sharp edge. Cold chisels, by contrast, are not sharpened and are tempered so that they will withstand the punishment of rock. They're cheap ($4) and well worth the labor of trying to get a sharp edge back on the wood chisel.
If you've scored a line with the with WF, a wide blade screwdriver would also work (provided it is hollow).
Yes, it looks like it could be a geode given the shape. If it's solid, scoring it with the WF will not be enough because you really need to set up a fracture through the stone. That's where the cold chisel comes in.
Post by mohs on Mar 4, 2009 15:45:51 GMT -5
I have a cold chisel around here plus I sharpen things so I'm not to concerned a Mexican geode ya think ? hope our sheriff Joe doesn't get wind of that I'll have I.C.E. at the door!!
I like to do the Eureka method it was Archimedes who first weighed the Kings crown in water They wanted to know if it was really gold and Archimedes was taking a bath and came up with the idea to weigh the crown against a known weight and
Eureka !!
he yelled as he ran naked into the city square with the amazement of his solution
I'll try to restrain myself :nono: !! if my rock turns out to be a geode :blush:
Post by Hard Rock Cafe on Mar 4, 2009 18:20:02 GMT -5
That's right; you did say you sharpen things.
It's generally pretty easy to tell a "floater" once you've hefted enough geodes. Some with a thick rind or filled with water can be a difficult test, though.
Be sure to post a pic of what you find! Chuck
chinook203
Member since February 2006
Post by chinook203 on Mar 4, 2009 21:42:46 GMT -5
I think its a Mexican geode also.....coconut geode.........they can be downright gorgeous inside
Post by mohs on Mar 4, 2009 23:28:25 GMT -5
Thanks guys! I definitely post pictures even if it crumbles or I chip my chisel :nono:
The neighbor wants to crack it along the longer oblong side. I was suggesting the shorter route. Make any difference?
Plus do you ever scribe a line? So you have something to follow when scoring it on the saw?
and how would you? I was thinking a chalk line snap a line
Post by Hard Rock Cafe on Mar 5, 2009 8:45:29 GMT -5
It doesn't make much difference which way you crack it. If you go the long way, the cavity will be more shallow. I just eyeball it when I'm cracking one with a chisel. I set the geode on the ground so that it is relatively stationary. After a few whacks there is a depression under it so that it doesn't roll. I think if you're rolling it on the saw, the blade should help keep you in a straight line. You could also wrap masking tape around it and mark a line on the tape, provided the saw didn't pull the tape off. It's not going to crumble. Now stop talking about it and do it! Chuck
Post by akansan on Mar 5, 2009 12:00:36 GMT -5
I'd say masking tape would be a great idea - especially if you went to just one side of center. The chalk line would come off fairly quickly, I would think, with the water...
Post by mohs on Mar 5, 2009 15:53:46 GMT -5
Ha ha chuck ! around here we don’t do anything quick Were contemplators! Mind power! we may crack that geode with just are brain waves ~~~~OOOOOOOOOMMMMMMMMMMMMM !~~~~~~~~~~~~~~ Yep I’m trying to find a compass to draw a line _______________________________________ There I go overusing my one brain cell again!
Post by Jack, lapidaryrough on Mar 5, 2009 16:40:00 GMT -5
Most coconuts have eye`s on them, i don`t see them in your photo. They`re the flow canals between geodes as they form from the outside inward, and base points of Crystal sites of growth. Though your`s is the right color For a Coconut, From the Red Bed Area, The Black Bed Coconut`s had black area`s on the outside. This photo is ( One ) of a 900 Lb. lot from Rocky Joe`s Rock Shop Agate Beach Oregon. Closed in 1991. Jack picasaweb.google.com/lh/photo/Zr0201fWpmEZ5vjIe-U30Q?authkey=Gv1sRgCO2q2Yz71ci8zgE&feat=directlink
Post by cpdad on Mar 5, 2009 20:45:06 GMT -5
go ahead and whack it already .....we waiting ;D....kev.
Post by mohs on Mar 5, 2009 22:51:33 GMT -5
ya can't rush a Michelangelo ! :nono: ;D
Post by mohs on Mar 7, 2009 19:37:00 GMT -5
I cracked this non-geode today and hearts came spilling out!!! ! Its a MIRACLE !!!! worthy of a Michelangelo
Post by Hard Rock Cafe on Mar 7, 2009 20:00:45 GMT -5
That's too bad. It sure looked like a geode from the pic. And I'm the one who said it wasn't going to crumble. Had it been a geode, it would not have.
For future reference, did you tap all the way around several times before it split, or did you give it a good whack?
Nice looking hearts!
Post by NatureNut on Mar 7, 2009 20:01:44 GMT -5
Nice hearts... crummy geode!
