nancyf
Wired Cowgirl
Member since April 2007
Post by nancyf on Sept 10, 2009 13:12:34 GMT -5
oh Randy! That is lovely...and the stone is gorgeous too!
pamee83
Member since December 2008
Post by pamee83 on Sept 13, 2009 8:52:10 GMT -5
Yes this really is a beautiful piece. I was the one to get it as a late birthday gift, but luckily I was able to view it here before actually getting it.
One of the 2 hoops you put on the back rubs against my neck and makes it unwearable, I guess I could either cut it off or twist it further toward the cab so as not to rub my neck anymore.
Pam
Post by Bikerrandy on Sept 13, 2009 9:19:59 GMT -5
One of the 2 hoops you put on the back rubs against my neck Really? They were flat and tight when I made it. The wire is soft, you should be able to push it flat again with something hard like a butter knife handle. Let me know if this works.
beachbabe
My little girl,Abbie, the other beachbabe!
Member since August 2009
Post by beachbabe on Sept 13, 2009 10:00:49 GMT -5
Hi Randy, I'm a newbie. Can you tell me what wire you used for this, is it Gold Filled? It's fantastic by the way. Thanks. Mary
pamee83
Post by pamee83 on Sept 13, 2009 10:20:46 GMT -5
Thanks Randy, the end of the loop had lifted while the rest was tight to the cab, I got the scratching end tucked in but now the rest of the loop is pushed a bit away from the cab...it hangs straight and doesn't bother my neck anymore so I'll leave it at that.
The "not so fancy" is perfect, any more than that and it would have lived its life in a box...I'll wear this one all the time.
Pam
Post by Bikerrandy on Sept 13, 2009 11:53:35 GMT -5
Cool, glad you like it and it's great to hear that it made the trip safely. Mary- Gold filled is the only way to go! I use 22ga square dead-soft for the wire wrap, and 21 gauge half-round/ half-hard for the bindings.
