Post by johnjsgems on Dec 18, 2009 12:32:46 GMT -5
Measure between the shafts and compare with the AR-1 in front of it. Barrel does fit very low down so maybe it was designed for larger diameter drum. The shafts are not like current Model B units. The orange tubing doesn't mean anything as a lot of people put whatever hose they have on old shafts as covering gets too slick or wears out A and B models all have motors mounted to side now like the AR-1 you have.
Post by deb193redux on Dec 18, 2009 12:44:15 GMT -5
This is some sort of consumer-modified machine. No manufacturer would make a machine where the height of the motor would not let you put a barrel on part of the shaft. Possibly, like John said, it is intended for a wider diameter barrel. (IF it was, you are turning the smaller barrel faster than recomended.) I think this cannot be the original motor. It is crucial to determine if the motor is stopping or if the rotation is not getting to the shaft. If the motor is stopping, then the motor shaft is not turning, and either the motor is bad, or some part of your sleeves/bearings is bad and giving more resistance than the motor can be expected to overcome. Like John said, if the shaft is turning, the next question is whether the drive pulley is turning. If not, you need to secure this pulley to the motor shaft better. IF the drive pulley is turning, is the driven (tumbler shaft) pulley turning. If not, then the belt is slipping. If the driven pulley is turning, is the tumbler shaft turning? If not, then the driven pulley needs to be secured more tightly to the tumbler shaft. In my experience with 2nd hand dual-3lb units, the motor is giving out. But check all the points between motor and barrel. I would not recommend buying a new manufacturers motor. 1) they are expensive, and 2) they usually have just enough power to turn everything if the sleeves/bearings are good and the belt is not too tight/loose, and the load is not too full ... etc. Generally they are 1/75th hp. - Unless it is intended for wider barrels and you get a new motor and a 12lb barrel. I would look for a cheap 1/20 hp or 1/12 hp motor that you could mount alongside the unit, not under the barrels. (Or at least I would jack up the unit, so the motor was further under the barrels.) This motor will have plenty of power to turn even gunky sleeves/bearings and to handle over-full barrels. The one disadvantage is that you need to custom-rig the motor mount, and get some custom belt to reach from the new motor location to the driven pulley. You also want to have the motor be able to slide a bit to let you tension the belt. You might consider putting the motor below the unit, bolted down, and then somehow varying the blocks thickness you use to jack up the unit so you can tension the belt. Or, you might put the motor in front of the unit and arrange so it can slide back and forth about an inch before you bolt it securely. (A motor with a foot plate with elongated bolt holes will let you do this.) This will look like way more of a contraption than it does now, but you will have shafts that should turn any barrels. This one is only 1/40 hp, and I would recommend stronger, but it is cheap: www.surpluscenter.com/item.asp?UID=2009121811205852&item=10-995&catname=electricthis one, also only 1/40 hp, is even cheaper: www.surpluscenter.com/item.asp?UID=2009121811205852&item=10-964&catname=electricThis is a slippery slope. The RPM of any surplus motor you find might require a different sized drive pulley to maintain the same barrel speed. Or, the drive pulley you have will not fit on the shaft fo the new motor. Or, you find a drive pulley for the new motor's shaft, but it is made for a wider belt than the typical o-ring type belt your driven pulley is made for. At some point, you start to think that if you are custom building the motor and redoing the belts and pulley's, why not also redo the frame to allow more/bigger barrels. I have been there and done that. The alternative is that you do get a Thumlers or Lortone motor used on their 12lb units (e.g., QT-66, AR-12) and it bolts in right where you have it now - but then you still have the problem of the motor blocking the 2nd barrel. Anyway, good luck. If you get a chance, post the hp and RPM and model# and anything else you can determine about the existing motor.
Post by superioragates on Dec 18, 2009 13:13:53 GMT -5
Ok, I cannot find any markings on the motor, from what I can see looking at the sides showing. So - I took some pics so you could see closer what it is I am working with. The orange on the shafts looks like it was built right on those shafts, and doesn't look like someone put it on there as replacement. I was only referring to that as maybe it would give some idea as to how old this thing is. I cleaned it up a little more, as best I could, without shutting it off, as my husband is the only one who can get the dern thing restarted, (he's at work right now) and I have propped up the motor end of it, so the barrel stays away from the motor, and so far it is staying in 1 spot.....this is good right? Here's the pics: You will notice the black tape I had to put on the shaft in an area, as the rubber stuff wore off in a couple of spots, so the barrel was just sitting there. This worked as a rigging for temp. fix.
Post by superioragates on Dec 18, 2009 13:17:20 GMT -5
MAN!! Looking at this thing in the pics........Maybe I'll just try to save some money and buy some thing else! This looks way worse in the pics!!! UGGGHHH! I couldn't get everything off of it when cleaning, but I will have my husband take it apart tonight and do a better job of that. I take it apart, and it will NEVER work again!! LOL Right now it's running....so.......I wanna leave it running as long as I can. The guy I bought it from told me to keep those bushings at the ends of the shafts with plenty of oil.....guess I'm doin that much right anyways!
Post by deb193redux on Dec 18, 2009 14:51:45 GMT -5
Well that looks like the original motor. So I guess it was designed for a wider barrel that would not fall as far through the shafts.
The good news is that one of the Model-B replacement motors would likely bolt right in. But they run about $70. You can find the motor for the Lortone QT66 for about $55, and it too face mounts so maybe you could bolt it right in.
But, I think ultimately you want to get a 12 or 16lb barrel to put on there. All of those parts begins to add up to the price of a new Model-B, which often goes onsale for as low as $130.
Post by johnjsgems on Dec 18, 2009 16:17:40 GMT -5
Other than the drum and red paint I don't see anything Thumler. Looks home made. The non pulley shaft has no bushings just running in a hole in frame. If motor is bad I don't think it would be worth replacing unless you can completely re-engineer the tumbler. I'd wait until after Christmas and watch e-Bay for all those unwanted Christmas tumblers or go to Cabellas or other reloading supply and buy a new one.
Post by superioragates on Dec 18, 2009 16:22:25 GMT -5
Ok guys, thanks. That's what I was afraid of. So.....if I look in to new tumblers, which is better.......a vibe, or rotary? I mean, If I am going to spend any money, I want to get something good, for the cost ya know? I'd like to be able to do more rocks at a time than what I am doing now, that would be nice.
Post by johnjsgems on Dec 18, 2009 16:32:19 GMT -5
I would stick with rotary myself. Either a Lortone QT66 (add a 12 lb barrel later) or Thumler's Model B. Your two 3 lb rotaries would be hard pressed to supply a UV10 vibe for finishing. A vibe won't make rounded pebbles. A smaller vibe will finish what your 3 lb units produce but good small vibes are not cheap either.
Post by superioragates on Dec 18, 2009 16:37:43 GMT -5
Ok, well, guess I start saving until I can get one. Thanks JS...I appreciate the effort you've gone to in helping me on this issue! Thanks to you as well Deb, I appreciate all your help as well! Marie
Post by deb193redux on Dec 18, 2009 16:41:22 GMT -5
If you plan to stick with polishing pebbles, follow John's advice. If you think more pre-forms are in your future, consider that they can go right into a vibe. ... and you can still use the small rotary to help feed the vibe.
Post by Sabre52 on Dec 20, 2009 7:18:49 GMT -5
Wow, that is odd. I've only seen a few Thumblers but I've never seen one with the motor mounted like that beneath the shafts. It looks like your small barrel is sunk pretty deeply between the shafts so I'm also thinking maybe that unit originally had a larger barrel.....Mel
gemhunter
"Rock On"
Member since November 2009
Post by gemhunter on Dec 20, 2009 7:27:13 GMT -5
:2cents: Looks like the rubber doesn't meet the barrel, and you definitely need stops. Have a great Christmas, maybe Santa will help ;D Ed
Post by superioragates on Dec 20, 2009 7:50:44 GMT -5
Yeah....thanks guys....but we have a deal in the house...Santas not comin 'round this year. That's ok tho, I'm just gonna run it till it dies I suppose, then I wanna get a BIGGER tumbler for MORE rocks!! LOL I followed suggestions made here, and so far has only stopped running 1 time since I started this thread, and running all night. It just keeps goin', so as long as it is, I'm a happy camper! I actually had to prop the motor end up like and inch & 1/2 to keep that barrel away from the motor, but it worked!
Post by johnjsgems on Dec 20, 2009 9:42:51 GMT -5
It dawned on me after seeing the close ups that the red things on the shafts are probably wheel arbor adapters (telescopic bushings). When it dies you should save it for parts. If you were mechanical you could move idler over, add bearings or bushings and have something that works. You would have to find bushings like Lortone and drill new holes. I'd cover shafts with braided vinyl hose also. Sounds like motor runs if everything turns.
Post by Jack ( Yorkshire) on Dec 21, 2009 1:13:48 GMT -5
Hi My "cts
Looks like you got a good tumbler just needs a bit of TLC I wish I could find one like that ata sale
A excelent rebuild project If you put some bearings in on that shaft it would go realy well im sure
Jack Yorkshire uk
Post by superioragates on Jan 2, 2010 9:51:42 GMT -5
Just so you guys know, this thing died. If we take the belt off, the motor runs, and turns smooth, put the belt on and it doesn't. I think the shafts need some bushings or whatever, cuz the belt is not slipping, it's like something is binding up the back shaft. B-4 I put a bunch of money in to this one tho, I am waiting to see if I can get a bigger tumbler, with bigger barrel etc. I have a dual action tumbler...OLD BUGGER, that I want to refurbish, and this motor might do the trick.......haven't had a chance to look in to it yet. I got that one from the same guy as I got this one from, and it worked for awhile, then the motor died......uggghhh!
